Need Help fixing a Code 22 and Code 52
Old Dec 21, 2024 | 02:55 PM
Green M4chine's Avatar
Ok so I really have no business trying to fix wires but I tried. I appeared to have made things worse. I was trying to splice in a new Coax cable for the knock sensor when I picked up the code 22. Lets work on the code 22. There is no retracing my steps at this point I am far beyond that.
I tried going from the ECT sensor and wiring a new Wire and attached it to THW at the ECu and the other one I did to a good ground. I replaced the ECT sensor twice and the ECT connector once. Now I am a complete novice at this but I don't understand where I messed up. I am prepared to be roasted although I hope I am close.
So then I tried to check voltage. So with Key in ignition and my MM on the hot wire and the other to ground I get a stupid low number... .0006 or something. Am I correct in thinking that it means my ECU is not producing enough voltage and should be replaced?
Then for like a week my Code 52 new coax cable started working well and I was flying around but with the code 22. Basically just had to turn the key 25 times in the morning to get it to start up and then I was usually fine for the day. But then i started touching wires again and now I am back to limp mode. I tried wiring the original wires for the ECT sensor and feel like I am even slower now than I was before. Been reading on this forum for a few years, I hoping one of you genius's can help baby step me through over the finish line.
Thanks,
Green Machine
1995 4Runner A/T 3vze
88Tyota
Jul 28, 2024 06:48 AM
Bbbradford61
Apr 4, 2024 06:28 PM
Kasan Blake Shedd
Feb 19, 2017 04:25 PM
Bazookaxxx
Aug 25, 2014 05:43 PM
yeehaw1
Feb 20, 2012 08:51 PM
