Four wheel drive issues
Old Apr 6, 2011 | 04:11 PM
PlayaCountryBoy's Avatar
I have a '91 4Runner and the four wheel drive is not engaging in the front differential. It has auto locking hubs. When I engage the 4x4 the front drive shaft turns but it's just not locking in there in the front differential. Any ideas on what to check to git 'er workin' again? All help is much appreciated!
Old Apr 6, 2011 | 04:50 PM
anthony1's Avatar
Isn't there suppose to be vacuum lines going to the diff? Check it. Hope you're testing this on dirt.
Old Apr 6, 2011 | 04:51 PM
Ricky B's Avatar
I'm kinda new to 4Runners but I believe the front axles are activated by air (engine vacuum). So you may wanna start looking under the truck and check for cracked/dis-connected/missing hoses.....
Old Apr 6, 2011 | 05:08 PM
Thanks guys! I will check the vacuum hoses manana.
Old Apr 6, 2011 | 05:13 PM
FourwheelinVT's Avatar
Don't know much about the auto differential disconnect(ADD), but it is operated by vacuum which engages a slide coupler in the driver side front axle shaft.
Old Apr 6, 2011 | 05:14 PM
justin_4runner's Avatar
you might want to do a little searching... there are tons of threads on fixing the 4wd. now depending if u are auto or manual there are many diffrent switches and vacuum lines, so when u put it in 4wd do u hear a click from the behind the dash? also here is a link for a repair manual for the 4wd..
http://www.ncttora.com/fsm/1993/susp...26addcontr.pdf
Old Apr 6, 2011 | 06:19 PM
jessed59's Avatar
my buddys runner did the same thing check/clean lines also check little vacuums in engine bay
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
skoti89
Jul 6, 2015 07:45 PM
