Cold Start Injector Troubleshooting
Old Apr 17, 2011 | 06:30 AM
pete c's Avatar
I have an '86 Toyota Sunrader motorhome with 22RE/auto.
It doesn't like starting cold very much. I will fire immediately, then crank....and crank....etc.
I get it started by just cranking for a moment. I repeat this 5-10 times till there is enough heat build up so that it catches and immediately settles into a low idle. When it is warm, it starts fine.
I am quite certain that the CSI is not doing it's job. I have checked the CSI timing switch. It measures about 50 ohms cold, raises a few ohms with it sitting in a cup of hot water. My haynes manual says it should measure lower when cold.
I have tried shorting across the timing switch connector, thinking this would trick it into a cold start condition, but the CSI does not fire.
Could someone give me a better explanation of exactly how this circuit works? I'd rather not sink a lot of money into the shotgun method of troubleshooting. Can I run 12VDC straight to the injector to test it? If so, is polarlty important? Is there a decent schematic of this circuit somewhere on this board?
TIA
Pete
Old Apr 19, 2011 | 11:49 AM
hashdfw's Avatar
I found the schematic elsewhere in this forum.
This morning I had what may be a similar problem. Little history first; my truck had sit for 8 years so the whole fuel system was plugged with gunk/rust, tank, fuel pump, pickup, return lines, injectors, filter etc. Last weekend I finally got all the injectors firing, parked it, refired it and it had a miss again which I figured, based on past experience with this truck, was a plugged injector. Before yanking the injectors (again) I jumpered the fuel pump on and let it run for a half hour, hoping to let the filter grab more gunk from the tank while the fuel flushed out the injector rails.
This morning I put it back together and it wouldn't start. It'd fire if I squirted carb cleaner into the intake, but wouldn't catch. It never had this problem before. I backed off the bolt to the cold start injector and no fuel came out. Before I always had fuel come out for quite a while after I shut it off since the rails are pressurized. This led me to believe I wasn't getting good fuel flow/pressure. I checked the filter - okay. The flow coming out of the regulator seemed good. I pinched off the return hose out of the regulator, which in effect bumped up the pressure in the rails but it still wouldn't start. Then I pulled off the CSI line, turned on the pump, and let it run into a catch pan for a few seconds. I put it back together and it started.
What I think happened is when I let the pump flush fuel through the system for 30m, a chunk of gunk got into the CSI supply line. When I pulled the line off it flushed the obstruction out.
Long story short, try pulling the supply line off the CSI and verify that you're getting good fuel flow.
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
