Auto transmission problem
Old Apr 11, 2011 | 07:03 AM
j111usa's Avatar
Hi guys. I have a 89 Toyota pickup 3.0 with a auto transmission that I just bought a couple days ago. Everything seemed fine with the truck until I tried to back up my driveway yesterday. The transmission started slipping really bad, the od light came on, and the truck wouldn't back up the steepest part. The engine just reved up and wouldn't move. Reverse works on flat ground ok it seems though. I checked the fluid level and it is ok. Could this be a solenoid problem? The guy I bought the truck from said he just flushed the transmission recently and I have read that could be a mistake. Anyway is there anything I can do to fix this or do I need a new transmission? Any help will be very appreciated.
Old Apr 11, 2011 | 07:46 AM
justin_4runner's Avatar
mine did about the same thing, but it started doing it on flat ground, i took it out and put a 5 speed in, did it for about the same price if u found a used one and installed it. i love the 5 speed...
Old Apr 11, 2011 | 08:58 AM
j111usa's Avatar
I just checked the fluid again and it is overfilled about a inch past the full mark. When I checked it yesterday it was cold and not perfectly level. Also it is slipping on level ground now probably was before I just didn't notice. Could the problem be too much fluid or a bad solenoid? I spent about 3 hours searching for answers on this forum last night but didn't find any. Thanks in advanced.
Old Apr 11, 2011 | 09:02 AM
j111usa's Avatar
Was the conversion a lot of work? Do you have to be a very experienced mechanic to pull it off. Thanks for the response.
Old Apr 11, 2011 | 09:14 AM
it wasn't too bad, worse part was the changing of the pedals, there is a couple threads on how to do this on the forums just need to do a search
Old Apr 12, 2011 | 05:50 AM
Marc's Avatar
Are you checking the fluid level while it's running?
Old Apr 12, 2011 | 07:49 AM
j111usa's Avatar
Yes, and at operating temp.
I'm currently looking into doing a 5 speed conversion though I really can't afford it right now. Thanks.
Old Apr 13, 2011 | 03:32 PM
weaselman's Avatar
pull some of the fluid out and see what happens. and i dont think it could be a solenoid. get a FSM and find the trans troubleshooting tips.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
