how to remove charge fuse under the hood ?
Old Apr 16, 2011 | 02:25 AM
mud toy's Avatar
Question how to remove charge fuse under the hood ?
I did a search on fuses and charging /not charging.
but couldn't find the answer
I thought it would just pull straight up and out, but I ended up pulling the top off of the fuse . I have an 89 yota 4x4 that wasn't charging when I bought it( a couple days ago)
sorrry if this is a newb question but this is my first yota.
Old Apr 16, 2011 | 07:16 AM
corax's Avatar
the wires are bolted on from underneath. There are several plastic clips around the edges that need to be released from the top. Sorta time consuming. Be careful as the case can easily be broken.
Old Apr 16, 2011 | 04:30 PM
mud toy's Avatar
thanks for the quick reply, I'll try to get it tomorrow if it doesn't rain.
Old Apr 16, 2011 | 04:34 PM
xxxtreme22r's Avatar
just an FYI that's the fusible link fuse, if that's blown you won't have any power in the truck at all. There is a separate 7.5amp normal blade fuse for the alt field winding's current.
80Truck
Oct 12, 2025 07:25 PM
theking11863
Mar 19, 2016 09:36 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
jjrbus
Jul 19, 2015 02:06 PM
rushw
Jul 18, 2015 01:46 PM
