How to manually wire a toyota fuel relay
Old Apr 10, 2011 | 09:39 PM
PHTH's Avatar
This relay came out of a 92 4runner v6, and to make a long story short i need to wire it manually. Does anyone know how to identify the pins?
Uploaded with ImageShack.us
Old Apr 10, 2011 | 10:26 PM
ToyoTech559's Avatar
looking at the second picture. if ur not gonna use the relay. i wanna say you jump the to top right pins on the fuse box. i looked on alldatapro and the fuel pump relay shows up as a circuit opening relay but it looks just like what you posted
Old Apr 10, 2011 | 10:37 PM
wyoming9's Avatar
Smile
If it does not show you on the relay some Toyota ones do others don`t.
Should be pretty easy to figure out with a multimeter the coil should have a resistance of between 40 to 60 ohms
The contacts should be open and read infinity if it is a good relay you are starting with.
Pins 1and 2 are the contacts
#4 is a coil coming from the air flow meter
#3 comes from the ignition switch
#6 goes to ground
pins 2and 3 are at the top with the relay held that way # 2 to the left
This has 2 coils that pull in at different times one at start and the other when it sees air flow via the air flow meter
Just what are you trying to do?
Old Apr 10, 2011 | 11:19 PM
PHTH's Avatar
Hmm. Awsome info. I'd like to hook the pump up to the ignition swith's on position.
I had this relay hanging around from a rig I parted out. So I figured I'd use it if I can.
If I can't I don't mind buying a generic one, but what amperage should I look for?
Old Apr 10, 2011 | 11:34 PM
vital22re's Avatar
totally a bro
so what are you using this for?
Old Apr 11, 2011 | 12:09 AM
PHTH's Avatar
I'd like to power my fuel pump with it. The wiring in my rig is all jacked and I can't get the fuel pump going the regular way. So I'm just going to power it myself
Old Apr 11, 2011 | 11:36 AM
vital22re's Avatar
totally a bro
well, I don't like to see people "hacking" thier rig. Why don't you tell us what diagnoses you've done and how you know its the fp not getting power?
Old Apr 11, 2011 | 04:17 PM
PHTH's Avatar
The fuel pump won't come on when I jump the +B and FP in the DLC1 port. The +B isn't even getting power. When I put power to the FP it fires up just fine. I have checked the ECU fuse and it seems to be working. I don't know what else it could be.
5280jo
10
Jul 13, 2015 10:05 PM
rbravo1
Jun 29, 2015 01:34 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
TheManOutside
Jun 18, 2015 03:32 PM
Dennis140
Jun 17, 2015 10:37 AM
