refilling power steering fluid
Old Apr 12, 2011 | 09:45 PM
dmaxxx21's Avatar
I have a 90 4x4 with 22re and just changed power steering pump and gear box and was needing to know how to refill the steering fluid, do I just fill the reservoir to the mark or what.
Old Apr 12, 2011 | 10:05 PM
jessed59's Avatar
ya i usually go a lil above it make sure to add fluid then move the steering around to get as much air out of lines as possible
Old Apr 13, 2011 | 04:21 AM
dmaxxx21's Avatar
When I get the air out do I do it with the reservoir cap off or what.
Old Apr 13, 2011 | 04:30 AM
xxxtreme22r's Avatar
correct procedure is in the FSM.
Old Apr 13, 2011 | 04:51 AM
waskillywabbit's Avatar
And you don't use power steering fluid
:wabbit2:
Old Apr 13, 2011 | 04:54 AM
:wabbit2:
Nice catch wabbit. That's why we pay you the big bux.
I just wish the dang FSM tells you the capacity of the system, but I looked high an low and couldn't find it in there.
Old Apr 13, 2011 | 04:58 AM
Between a quart or two of ATF, not power steering fluid unless installing complete aftermarket steering that requires ps fluid like full hydro, then use expensive synthetic stuff. Fill up reservoir. Put front on jackstands. Run engine. Cycle steering 20 times. Let it sit 30 minutes for air to get out. Repeat until no bubbles after cycling and then fill reservoir to "hot" line. Works for hydro assist too.
:wabbit2:
Old Apr 13, 2011 | 05:01 AM
I followed the part that says undo the return line and plug off the bottom of the res and dump fluid into container till no air comes out. went through a qt and a half that way so I guess I gave it a good flush then. Never did put it on stands though. Still think there is some air in mine. Got to get back out there and do some more.
Old Apr 13, 2011 | 05:06 AM
Above way takes longer but heck of a lot less trouble or mess. Go do something else while you're waiting. Works every time.
Note the above procedure is with the reservoir cap OFF.
:wabbit2:
Old Apr 13, 2011 | 05:15 AM
haha I'll agree on the messy part. Lets just say that my newly painted flat black gearbox is now a satin black gear box. lmao.
Zpd426
Jan 2, 2016 01:15 PM
gmonnie123
Jul 26, 2015 02:44 PM
keithporter83
Jul 24, 2015 07:37 AM
yoterr
Jul 24, 2015 04:29 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
