3vze overheating when towing or sitting in traffic
Old Apr 4, 2011 | 05:27 PM
ACLambert's Avatar
Howdy im new here. Im having a problem with my 95 4-runner with the infamous 3vze ( I know its a piece O crap Dont remind me). When towing since first week of ownership (even an unloaded 4x8 trailer on flat ground ) the motor will over-heat and puke coolant out. I know its not the head gaskets, the water pump is good, new thermostat with two 1/8" holed drilled at 12 and two o' clock,
new radiator (all air out), new a340h transmission, have tried a fully locked clutch fan, a brand new clutch fan. even tried direct wiring the ac fan to a switch on the dash
Any info on this could help Thanks in advance
Old Oct 7, 2011 | 06:02 PM
the beav's Avatar
dont know if you got your problem fixed or not . but are your rad hoses in good shape . if there really old they can seperate and pinch off on the inside .
it's happened to me before . goo luck .
Old Oct 8, 2011 | 02:22 AM
954x4runner's Avatar
Don't overheat it to a point that coolant spills out. My truck would run hot for a very brief moment, coolant didn't even spill out yet and my truck blew a headgasket. Don't drive it till you fix it. I thought id be fine but my truck is currently down.
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
vanion2
Jul 29, 2015 06:17 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
