3 VZE valve clearance
Old Apr 6, 2011 | 08:53 PM
jojapro's Avatar
Im wondering wether or not to change a few valve shims. According to the FSM the minimum exhaust clearance (lobe to valve shim) is .009 inches. Three of my valves are right at .009. I have read that it is better to have them a bit loose then too tight. Also one of my intake valves is right at the max clearance, .011 inches. Any opinions?
Old Apr 7, 2011 | 02:38 AM
TNRabbit's Avatar
Try swapping the shims on those two that are on the edge.
You should still be ok either way. Too loose IS better, as when these wear they actually get TIGHTER.
bigjstang
Jun 2, 2025 03:56 PM
foampile
Dec 18, 2022 01:29 PM
Blamalam
Mar 12, 2022 07:34 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
