93 V6 Auto 4X4 A/C Compressor Replacement
Old Apr 6, 2011 | 08:15 PM
MacDaddy's Avatar
Newby..Looked everywhere for a write-up on AC compressor replacement. Any help would be appreciated. Compressor housing leaking and looking to replace. Saw some on line ranging from $170-$300+. Why the huge diff in $$? Saw a Denso for $273. Is this a PITA project?
Old Apr 7, 2011 | 02:40 AM
TNRabbit's Avatar
You might end up replacing seals throughout if it's been out for while, and it is sort of a PITA.
Best place I've found for Denso replacement (only way I'd go) is www.sparkplugs.com
Old Apr 7, 2011 | 07:27 AM
MacDaddy's Avatar
Thx Rabbit. Still can't find write up on a/c replacement in knowledge base. FSM ain't that helpful either.
Old Apr 7, 2011 | 11:14 AM
TNRabbit's Avatar
That should tell you something~…………
Old Apr 7, 2011 | 11:53 AM
MacDaddy's Avatar
Well I got a guy that swears he can do the compressor, and he owes me. FSM says to drop the P/S pump in preparation. Saw that on a timing belt thread and even that looked like a PITA. Oh well...no guts, no glory. Gotta have air in the "dry" heat of AZ. Will post anything that might help the next poor SOB.
Old Apr 21, 2011 | 06:15 AM
jtravis's Avatar
Curious to know how you're doing on this project. I'm in the same boat--need to replace the compressor on my 93 V6 3vze auto.
Just so happens I need to swap out my leaky PS pump, too . . .
Happy to help if you're nearby! (It would sure help me . . . )
Old Apr 21, 2011 | 02:04 PM
MacDaddy's Avatar
jtravis...I'm in AZ. I am scratching up the $300+ to get the parts. I will try to document what we do and pass it on. Probably good idea to knock out the P/S pump while your doing yours. I'm all about fixing stuff if its in the tear-down of another component. Gonna do my timing belt and replace the W/P while I'm in there even though its working fine.
Old Apr 21, 2011 | 02:41 PM
MacDaddy's Avatar
'93 V6 A/T 4WD Runner Code 25
Put what I suspect was crappy fuel and now have engine that feels like it's running on 4-5 cylinders. Got a Code 25. Will check for vacuum leaks. I see members refer to "SeaFoaming" vacuum system. Bought a can and would like to try this. Can someone point out exactly where I introduce the Seafoam and is it done w/ engine running @ a certain RPM, etc..
Old Oct 6, 2013 | 09:55 PM
Nestos4runner93's Avatar
I am in the middle of replacing the head gaskets when I noticed that the belt for the a/c wasn't even on. Figured it must has been a problem before so PO just cut belt to save $$.
Old Oct 6, 2013 | 10:55 PM
wyoming9's Avatar
Red face
two year old thread.
If you don`t have the tools and know how it can be a real pain.
Most compressor swaps for a warranty need to be signed off by a licensed AC tech last I looked.
It sucks to spend the money for a new compressor and dryer only to have your evap coil look like it was shot with bird shot
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
zd92655
Jul 5, 2015 04:25 PM
