86 22rte cold start issue
Old Apr 14, 2011 | 05:02 PM
jeetS's Avatar
86 Strange 22rte cold start issue
I have this very frustrating cold start issue.
When the truck is cold or hasnt ran for over a couple hours, I have to crank it for ten seconds, then pause...then crank(it tries to start)about 5-10 times more till it finally coughs to life. If it runs for a minute and I turn it off it fires up instantly again when I try.
Its getting very frustrating.
No vacuum leaks
new fuel pump(did it with the old one too)
changed the cold start time switch
changed the cold start injector
what other sensors/places should I be checking?!?
Thanks guys
86 turbo 4x4 5spd reg cab
Old Apr 15, 2011 | 09:51 PM
jeetS's Avatar
bump
this is not your typical cold start issue...
Old Apr 16, 2011 | 06:03 AM
mldave's Avatar
Had a similar problem.I'm not mechanical at all but here are a few things I've read on the internet after searching for months.Thermo temp sensor,next to the CSI switch..banjo bolt..fuel rail leak,fuel damper below the t-stat housing.Finally just had a fellow bypass the CSI with a toggle switch,starts every time.Not the correct way but it works.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
jmc88runner
Jun 18, 2015 03:39 PM
