94 truck will not crabk after timing kit replaced
Old 04-12-2011, 10:43 AM
fountain's Avatar
94 truck will not crank after timing kit replaced
Guides broke and installed whole new kit from engnbldr. The gears are in correct and aligned right. Put on tdc and installed distributor at 12 o clock and it rotated perfect to# 1. Won't crank. We tested with timing light as we were trying and it all was in time and hitting good time. Not sure what to do now. We did not remove head or anything fuel relayed. Getting fire on all plugs. I do know that the alternator ground is not hooked up. What else do I do look to? It seems as if it is 180 out or something. Im baffled
Old 04-12-2011, 11:32 AM
4Crawler's Avatar
Assume a 22RE engine?
When you say "won't crank", do you mean the starter is not running?
Or that it tries to run but can't turn the engine over?
Or is it turning over and not starting?
Hard to tell from the vague description of the problem.
Old 04-12-2011, 12:08 PM
Sportsmanphil's Avatar
My 22RE has #1 at the 10'oclock position roughly.
Old 04-12-2011, 12:15 PM
92 TOY's Avatar
make sure it looks like this----->>>> https://www.yotatech.com/forums/f116...l#post51463797
Old 04-12-2011, 12:40 PM
fountain's Avatar
yep...it fell back to 10 o clock position when put in at 12 o clock..and points to #1, but will not crank. it turns over and over, but will not crank up or remotely act like it wants to.
Old 04-12-2011, 12:51 PM
OrRunner's Avatar
are you getting fuel at the injectors or CSI? you said you have spark at the plugs, so i would check that next
Old 04-12-2011, 01:07 PM
92 TOY's Avatar
coil wire on?
plug wires correct?
check CSI as stated above?
gas in the tank? (i'm not being sarcastic....just make sure)
if you only did the front end, you should have only removed the 1 ground wire by the alternator....you already mentioned that.
EFI fuse?
Old 04-12-2011, 01:16 PM
fountain's Avatar
i know the alternator wire was not on..but i didnt think that would stop it from cranking.
Old 04-12-2011, 01:19 PM
peow130's Avatar
Everything plugged in?
Old 04-12-2011, 01:21 PM
Marc's Avatar
crank is the same as turning over
fire is the same as start or spark
Old 04-12-2011, 02:29 PM
fountain's Avatar
ok...it will not run..it will turn over fine, but will not crank up and idle for those that are not completely unsure of what i am talking about. in the south cranking it the vehicle firing up and running...not doing anything is nothing
Old 04-12-2011, 03:32 PM
peckinpah's Avatar
OK, good. After reading the thread title, I thought you found a crab under the hood or something.
voiddweller
19
05-02-2016 09:10 PM
zytra
06-24-2015 08:14 AM
Taz22R
06-21-2015 04:44 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: 94 truck will not crabk after timing kit replaced
