Fuse Keeps Blowing!
Old Apr 8, 2011 | 01:22 PM
Evrgrnmtnman's Avatar
Fuse Keeps Blowing!
I have a 15amp fuse that controls the gauges and tachometer that keeps blowing on my 88 Toyota pickup. Seems to blow when the engine is started or shut off. Thinking a short or power surger. Was hoping someone might have experienced this and know what is going on?
Thanks,
CJ
Old Apr 8, 2011 | 02:01 PM
86yota321's Avatar
If it's the one I'm thinking of, it's the 'engine' fuse. Does your charge light come on when the fuse pops?
Old Apr 8, 2011 | 02:17 PM
You are correct! It comes on too
Old Apr 8, 2011 | 02:30 PM
86yota321's Avatar
I had the same problem. I switched out my alternator with a spare I had. Haven't had an issue since. I think it was a faulty regulator that was sending, like you thought, a surge through the line.
Old Apr 8, 2011 | 02:34 PM
That sounds very possible. I did have the alternator checked at NAPA and it was okay, but that doesn't mean something else inside it could be causing it
Old Apr 8, 2011 | 02:43 PM
86yota321's Avatar
I had both alts tested and they both came back good also. Mine would happen at so many different times, but work fine for a day or two then back to blowing fuses. If you swap out with a new one and it still does it then you're chasing a short.
Old Apr 8, 2011 | 03:14 PM
Sounds like a good plan. I'll do a replacement.....
Thanks!
puddlepirate
Jul 30, 2016 06:29 PM
4banginRunner
Nov 13, 2015 05:23 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
