Auto Trans advice needed please
Old Apr 19, 2011 | 03:44 PM
markfagus's Avatar
Question Auto Trans advice needed please
Guys, I have a 88 3.0 auto. When I bought it a few months ago it had been sitting for 2+ years. I did the head gasket and a few other issues and now am tackling the tranny issue that has been there since I got the truck.
It shift fine in R and thru 1-2-3 but will not go into OD. I disconnected the computer under the console and test drove it shifting manually and OD did engage. So I assumed it was a solenoid issue. I replaced the solenoids (all of them) and I am still not getting OD.
I initially checked everything under the hood so I know it is not an issue there.
Could it be the ECT computer that is an issue? Do these things ever fail? Or is it time for a rebuild on the tranny?
Any advice you can give is greatly appreciated!
Mark
Old Apr 19, 2011 | 05:00 PM
markfagus's Avatar
ADMIN, can you kick this fool out of here?
Old Apr 19, 2011 | 05:05 PM
swampfox's Avatar
Check the temp sensor for the trans ecu to see if the wire is damaged or it has a bad sensor.I am not sure which one it is but it should be next to the engine temp sensor.
x2 on kicking the fool out.
Old Apr 19, 2011 | 06:42 PM
jbtvt's Avatar
OD also won't work if your fluid level isn't right on, it's really sensitive and can be tricky the way their hot/cold ranges are laid out. Check the manual for the exact temp range and use a thermometer if possible to make sure you're in it. Hot range seems to be more accurate. Might also try flushing and replacing with Valvoline Maxlife, good stuff.
Old Apr 19, 2011 | 07:13 PM
markfagus's Avatar
jbyvt, fluid level is spot on. i wish it was that easy.
I was able to get OD to work when I disconnected the box under the console.
Old Apr 19, 2011 | 08:32 PM
ToyoTech559's Avatar
my problem was a sticking T-Stat. causing the engine to never reach operating temp. make sure your reaching operating temp
Old Apr 19, 2011 | 08:37 PM
markfagus's Avatar
I don't think that is it, this issue of no OD was happening before and after I replaced water pump and t-stat. Engine operating temp seems not to be the issue.
Keep the ideas coming, I am all ears and my patience is wearing thin...
Old Apr 20, 2011 | 09:21 AM
jbtvt's Avatar
If you're sure of all this probably time to tear into it. Maybe try the diagnostic but I can't vouch for it personally. Guessing you have the A340H like I'm pretty sure I do on my '88? All the info you'll need from basic to rebuild at
http://www.pirate4x4.com/forum/showthread.php?t=587521
Old Apr 20, 2011 | 09:38 AM
McKenna's Avatar
Did you change out the Solenoid in the T-case as well ? I know you said all of them but some people only mean the ones attached to the trans.
Old Apr 20, 2011 | 12:07 PM
markfagus's Avatar
McKenna, I did not change that one. I bought a kit and replaced all that were in the kit (the ones in the tranny)
Could the solenoid in the t-case cause the problem I have described?
Old Apr 20, 2011 | 12:21 PM
McKenna's Avatar
I believe the Solenoid in the T-Case is your OD solenoid, from what I remember.
vasinvictor
Jan 20, 2016 12:39 PM
BLRobertson
3.4 Swaps
Jul 10, 2015 04:27 AM
BigArt70
Jun 30, 2015 09:51 PM
HALMAN
Jun 14, 2002 09:02 PM
