86 22 re starting problems?
Old Aug 12, 2010 | 05:47 PM
706th1's Avatar
1. It would not start just turn over.
2. spray starting fluid in air box, it starts and runs fine.
3. changed fuel filter. It still just turns over.
4. Its pumping fuel to filter, have not checked anything else.
5. What would be the problem?
Old Aug 12, 2010 | 07:25 PM
skoti89's Avatar
not a mechanic at all, but i would maybe check make sure all your plugs are in all the way and the wires too. ignition coil plugged in?. this happened after i did my timing chain, didnt have my distributor rotor at top dead center and pointing at plug number 1 or whatever(i had it 180 degrees off...lol)
Edit, i didnt read number two were you said it would start when you sprayed the air box....mine wouldnt start at all
Old Aug 12, 2010 | 07:44 PM
myyota's Avatar
After you spray the starting fluid in the air box and it starts, does it stay running after that or does it quit again ?.
Old Aug 13, 2010 | 05:32 AM
706th1's Avatar
It stays running after spraying starting fluid in the air box.
Old Aug 16, 2010 | 06:11 PM
706th1's Avatar
does anybody have any sugestions?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
