86 22 re starting problems?
1. It would not start just turn over.
2. spray starting fluid in air box, it starts and runs fine.
3. changed fuel filter. It still just turns over.
4. Its pumping fuel to filter, have not checked anything else.
5. What would be the problem?
not a mechanic at all, but i would maybe check make sure all your plugs are in all the way and the wires too. ignition coil plugged in?. this happened after i did my timing chain, didnt have my distributor rotor at top dead center and pointing at plug number 1 or whatever(i had it 180 degrees off...lol)
Edit, i didnt read number two were you said it would start when you sprayed the air box....mine wouldnt start at all
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
