lost dash lights
Old Aug 17, 2010 | 04:11 PM
tktmsa's Avatar
lost dash lights
Lost all my dash gauge lights, the fuse is fine, the clock, and radio are functioning - any place else I should be looking at? '94 runner 3.0 5sp
Old Aug 17, 2010 | 04:22 PM
gary_the_4runner's Avatar
its gotta be fuse 15 amp (blue) blade by your feet, driver side
Old Aug 17, 2010 | 04:44 PM
yotarover's Avatar
i lost all of mine as well every fuse is perfectly fine. some days it would come on in the past now it doesn't light up anything.
Old Aug 17, 2010 | 05:21 PM
88redyota4x4's Avatar
does yours have one of the dimmer switches, could be disconnected maybe or just turned down, something to check
Old Aug 17, 2010 | 05:57 PM
tj884Rdlx's Avatar
see if you have heater control panel lights, and that they dim up and down with the dimmer switch.
if they're out, it may be that switch. if the clock doesn't dim with lights on, it may be the headlight switch.
if they work fine, and it's just at the gauge cluster, pull the top of the cluster off and check the three plugs at the back of it. if someone has pulled that cluster out in the past, a connector may not be seated.
good luck!
Old Aug 17, 2010 | 06:12 PM
tktmsa's Avatar
the clock light does not dim with the lights on, and I get nothing on the dimmer - no heater control lights at all. I did find a blown 15a tail light fuse, replaced it thinking it may have something to do with it. nada. Where is this headlight switch?
Old Aug 17, 2010 | 06:42 PM
yotarover's Avatar
yeah i have a dimmer it's turned all the way up, haven't checked to see if it's became unhooked. i noticed months ago that when i went through water puddles my lights would work and then when it was really dry it wouldn't it's weird
Old Aug 17, 2010 | 07:18 PM
MudsharK's Avatar
Same thing happened with my 87 pickup...turned out to be a wire for the tail lights shorted out, i believe the dash lights are on the same circuit as the tail lights on my truck anyway... good luck
Old Aug 18, 2010 | 07:38 PM
tktmsa's Avatar
I keep popping the tail light fuse, any ideas?
Old Aug 19, 2010 | 03:41 AM
yotarover's Avatar
yep get some trailer lights ground them off and tie them in with the cd player never forget to turn them off or on like most of us the cd player is always on when we're driving and off when we cut the truck off
Old Aug 19, 2010 | 08:19 AM
mountaingoat's Avatar
Pull both tail light bulbs and check the sockets for corrosion, I had a corroded socket and it was popping a fuse on me.
Also, the fuse panel itself can get broken - there's a bunch of flat circuits behind the fuse panel that are sort of easy to damage, I busted one of mine when inserting a fuse tap and had to get a new (used) fuse panel. (My dash lights were knocked out by the broken circuit.)
Old Aug 19, 2010 | 06:18 PM
tktmsa's Avatar
I'll be putting in new tail bulbs and will report.
Old Aug 19, 2010 | 07:57 PM
tktmsa's Avatar
Found a loose connector in the tail light- fixed !!
Old Aug 19, 2010 | 08:57 PM
Right on!
Old Aug 21, 2010 | 08:20 AM
tktmsa's Avatar
And the lights popped off again going around a corner - trying to find the offending wire.
ashersullivan88yota
Jan 18, 2022 05:37 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
