pinging
Old Aug 14, 2010 | 11:39 AM
cucky16's Avatar
pinging
My truck pings alot so i unpluged the KS and it don't do it with it unpluged what can i do to fix that
Old Aug 14, 2010 | 11:41 AM
85gijunk4x4's Avatar
3vze?
22re?
Old Aug 14, 2010 | 11:53 AM
cucky16's Avatar
it's a 22RE
Old Aug 14, 2010 | 12:02 PM
xxxtreme22r's Avatar
fuel filter, fuel pump, injectors, bad gas, carbon build up on pistons, vacuum leak. all can cause a ping. probably forgot to mention some more, not sure what the side affects are of not having that KS unplugged though. Yet another eason why I like my carbed truck. it runs the way I tell it to run.
Old Aug 14, 2010 | 02:02 PM
myyota's Avatar
Make sure the timing is set properly, replace the fuel filter if its been a while sense it was done and see if that helps. If it doesn`t, then get some sea foam and run some through the intake and put some in the gas tank, that will clean out any carbon build up in the engine. How many miles on the engine ?, has the timing chain ever been replaced ?.
Tacoma1313
Aug 17, 2015 05:44 PM
83flatt
Jul 2, 2015 10:30 AM
bobbybouche
Jun 18, 2015 10:22 AM
rimpainter.com
Jan 8, 2004 06:53 PM
billyhub
10
Feb 3, 2003 05:18 AM
