Pre 84 Trucks 1st gen pickups
double row TC 22r strange pinge/clack/knock from driverside under cab
Old Jul 1, 2015 | 12:01 PM
83flatt's Avatar
Hi this is my first post I've searched and searched can't find anything close to what I'm dealing with.
I have a ping going on at idle and while under load (not cruising with little throttle or at least i cant hear it then) when idling and looking head on at engine or on exhaust side it cant be heard walk to driver door its plain as day. Its a 5spd early 22r carb with dbl timing chain. Valve clearances are correct. Exhaust manifold isn't leaking from what I can tell/hear/feel
Anyone have any ideas on where I should look next? Transmission or downpipe I'm stumped. Any thoughts would be awesome!!!!
Old Jul 1, 2015 | 02:51 PM
Bingle's Avatar
Pinging under load is usually a timing issue (too advanced), but if it's there at idle and more under cab on exhaust side then sounds like exhaust leak or interferance between exhaust and cab/frame?
Get under while idleing and really try to track down where it's comming from.
Old Jul 1, 2015 | 03:20 PM
83flatt's Avatar
Timing. Didnt think about that. Definitely need to check it but its probably something hitting like you said. Someone made a comment about It being trans related but I don't see how that's even possible since its manual; or is it possible.
Old Jul 1, 2015 | 03:28 PM
Bingle's Avatar
Not very likely trans related if it can be heard while in neutral, if it did there'd likely be no question it was trans related when you put it in gear and tried to go somewhere. exhaust leaks can sound like a ping. stock exhaust or headers etc.?
Old Jul 2, 2015 | 10:30 AM
83flatt's Avatar
In some ways it sounds like detonation but its to far down the pipe for that I think but I'm about to go out and look around for the source I appreciate your advice/input/help!!
young buck
18
Aug 27, 2018 02:40 PM
dumpster84
Apr 30, 2016 06:03 AM
theking11863
Mar 19, 2016 09:36 PM
redneck17
Aug 12, 2015 08:15 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
