Pre 84 Trucks 1st gen pickups
Location of Accessory Wire to tie in new deck
Old May 30, 2015 | 07:21 AM
TheSkiingNinja's Avatar
Hi all,
I added a BT deck in the glovebox but I'm having difficulty locating the accessory wire so the deck turns off when the vehicle is not in use.
Not really relevant to this post but here is the truck.
Thanks!
Old Jun 1, 2015 | 09:46 AM
kawazx636's Avatar
There should be a Light Blue w/ red stripe wire coming off of the main harness right behind the radio. That wire runs back to the ACC power on the ignition. If you can't find that then you can either run a new wire back to the ACC power or use another wire that has 12V with the ignition on and 0V with it off.
Old Jun 3, 2015 | 01:56 PM
The only thing I see that resembles that is this:
I don't mind running a new wire if the above can't help me; I'm just not sure where to run it to.
Thanks,
Sean
Old Jun 3, 2015 | 02:59 PM
kawazx636's Avatar
That would be it. The blue/red wire is your ACC power (to turn on the radio when the ignition is on) and the greens are your speakers. If you are installing a modern radio then you'll need to run a wire (with inline fuse) to the battery for constant power.
Old Jun 10, 2015 | 06:18 AM
That wire is dead so I just tied into the fuse panel. Works great.
Thanks!
Old Jun 29, 2015 | 12:21 PM
msane99's Avatar
cigarette lighter power lead is ignition switched. door courtesy light is always on(constant). I know you worked it out but if anyone else needs information. Short run to the cigarette lighter.
Old Jun 29, 2015 | 12:54 PM
shadowbirdie's Avatar
New naming issues
For the youngins, I believe the PC term is Power Port, with the correct part inserted though, it still lights cancer sticks of all types
Works with no key?? Not in my vehicles factory original,
but I have hooked most up manually to work all the time
out of general laziness
Have a great day!!!
Old Jun 30, 2015 | 02:11 AM
msane99's Avatar
oh yeah power port lol power port needs key yes. courtesy light does not. that's what I was trying to say anyway. Still have an old GM van I can always walk out to light whatever without key. Love them old American cars..
Old Jun 30, 2015 | 03:12 PM
Ya But...
You can also walk out to a dead battery, nothing is free...
Old Jul 6, 2015 | 04:57 AM
RobotMoose's Avatar
Or you could play mad scientist and wire five "power ports" into the car directly from the battery and charge or light whatever you want whenever you want!
If your lighter is draining your battery, something is grounding out somewhere.
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
jetspeedz
Jul 13, 2015 09:32 PM
94whiterunner
Jul 12, 2015 07:15 PM
toyota32
Jul 6, 2015 05:42 PM
