leaf spring flaring
Old Aug 19, 2010 | 05:22 PM
chuckn1's Avatar
leaf spring flaring
hey check out my leaf springs. i dont know if there supposed to do this because there aftermarket skyjacker TR40S but this is what the rear driver side looks like and its the only one that does this. is there a simple fix?
Old Aug 19, 2010 | 05:37 PM
PismoJoe's Avatar
Yup...very simple fix. Someone did not install them properly or did not torque the U-bolts properly.
-Jack the axle up, and the body so that there is no weight on the leafs
-loosen the u-bolts
-take a hammer and hit the overload spring back into place, so it lines up again
-make sure when you tighten the u-bolts back, they are torqued EVENLY @90ft/lbs
Old Aug 19, 2010 | 05:41 PM
yotaman85's Avatar
has nothing to do with how tight the u-bolts are (mostly). they should have another spring clamp on them like the one in the top pic foreground.
Old Aug 19, 2010 | 05:45 PM
PismoJoe's Avatar
Yeah your right if the U-bolts are loose that wont happen
Old Aug 19, 2010 | 06:23 PM
scuba's Avatar
My vote is for the spring pack centering pin not tight enough.
Old Aug 19, 2010 | 06:39 PM
yotaman85's Avatar
your right, I did say mostly... the loose u bolts can cause it to happen. but the center bolt is more likely. thanks scuba.
Old Aug 19, 2010 | 07:53 PM
PismoJoe's Avatar
hehe just giving you a hard time and yup that is a possibility also scoob
Old Aug 19, 2010 | 09:17 PM
whokrz's Avatar
Center bolts keeps the leafs and axle lined up front to back.
Clamps keep the leafs lined up side to side.
Ubolts keep the axle connected to the spring.
The lowest leaf on my front pack used to do that when I took it off road. Clamp the spring.
Zach_trun
Jan 22, 2020 04:42 PM
MichaelKLerner
Oct 27, 2015 07:18 PM
ktm192k
Sep 24, 2015 03:36 PM
sonorn67
Sep 19, 2015 05:39 PM
Jake28296
Sep 16, 2015 06:10 AM
