Another speedo problem.
Old Aug 18, 2010 | 04:38 PM
zookce's Avatar
Hey everyone,
I tried searching but no one seems to be having a problem quite like mine. Every morning my speedo doesn't work (just stays at 0) for about the first 10 minutes or so, then jumps up to correct speed. Works fine for the rest of the day. The odometer works the entire time, not problems with it. I thought it may be the speed sensor, pulled it, it looked fine. The dealer told me that if the odometer is working, it must be the speedo itself. Sounds right to me. Any other ideas? My speedo is all electrical, and I have no tach or trip. Would a cluster w/ a tach and trip work in my truck? Thanks for your help. I have a 94 pickup with manual tranny, 4X4, 22RE.
Old Aug 18, 2010 | 05:55 PM
yardleyto's Avatar
Electrical contact only making contact when metal swells when warm. look for loose connections or slightly broken solder joints
Old Aug 18, 2010 | 06:53 PM
iamsuperbleeder's Avatar
sounds to me like the cluster's going out; or at least the speedometer in it is going
it would be a good time for an SR5 cluster upgrade
https://www.yotatech.com/forums/f116...w-pics-179106/
Old Aug 19, 2010 | 08:21 AM
Mike Shull's Avatar
Is your spedo electric or cable? I have two cable type spedos here...they go bad sometimes.
Old Aug 20, 2010 | 12:12 PM
zookce's Avatar
Hey,
thanks for all the info. Bleeder, I checked out your SR5 upgrade! That is awesome. I haven't decided if I'll go for, or just put the same cluster in again. Money is always a factor. I'll let you know how things turned out.
Steven.m.paulk
Jun 7, 2020 10:45 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
voiddweller
Sep 28, 2015 11:21 PM
charlie_fong
Sep 27, 2015 10:06 PM
