Creaking/Squeaking in front left side.
Old Aug 20, 2010 | 04:44 PM
throwbro's Avatar
I have a Creaking/Squeaking sound in my front left side of my 94 4runner. I am having a hell of a time telling what part it is coming from.
It only happens when I am turning left while going over a bump. I figure maybe the CV joint but I can't tell. Anyone have any insight on this issue?
Edit: The noise is while moving, I can also rock the front end up and down while turned left and it will do it. It doesn't happen when the tires are straight.
Old Aug 20, 2010 | 04:56 PM
myyota's Avatar
Have someone rock the front end up and down while you climb under it and try and pin point the noise.
Old Aug 20, 2010 | 05:03 PM
BMcEL's Avatar
Most likely the wheel stops...throw some grease on them and see if it still does it.
Old Aug 20, 2010 | 05:36 PM
scope103's Avatar
There are plastic caps (x4) on the steering stops, popularly called "groan stoppers." They do wear out, and you can stay ahead of the issue by just greasing the metal ends. But the caps don't cost much, and they do last longer than grease alone.
To tell if that's the problem in the first place, add some grease to see if you get an improvement.
Old Aug 20, 2010 | 05:41 PM
throwbro's Avatar
That was it. I never would have thought of that. Thanks, its now fixed.
Old Aug 20, 2010 | 05:48 PM
BMcEL's Avatar
Glad I could help!
Old Aug 20, 2010 | 06:29 PM
Exiledbikr's Avatar
Mine does the same, where are the wheel stops located? lol im a little new to toyota
Old Aug 20, 2010 | 07:09 PM
BMcEL's Avatar
On the lower control arms right by the ball joints. Can't miss them.
Old Aug 20, 2010 | 07:29 PM
Exiledbikr's Avatar
Alright thanks man
Old Aug 20, 2010 | 07:40 PM
iamsuperbleeder's Avatar
top/center of this photo is a steering stop and plastic cap
so you know what you're looking for
Old Aug 20, 2010 | 08:31 PM
Exiledbikr's Avatar
Thanks man i really appericiate it!
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
terminator
Jul 27, 2015 07:13 PM
CanRunner
Jul 20, 2015 01:29 PM
