Creaking/Squeaking in front left side.
I have a Creaking/Squeaking sound in my front left side of my 94 4runner. I am having a hell of a time telling what part it is coming from.
It only happens when I am turning left while going over a bump. I figure maybe the CV joint but I can't tell. Anyone have any insight on this issue? Edit: The noise is while moving, I can also rock the front end up and down while turned left and it will do it. It doesn't happen when the tires are straight. |
Have someone rock the front end up and down while you climb under it and try and pin point the noise.
Most likely the wheel stops...throw some grease on them and see if it still does it.
Originally Posted by bmcel
(Post 51530213)
To tell if that's the problem in the first place, add some grease to see if you get an improvement. |
(Post 51530213)
Originally Posted by throwbro
(Post 51530234)
That was it. I never would have thought of that. Thanks, its now fixed.
Mine does the same, where are the wheel stops located? lol im a little new to toyota
On the lower control arms right by the ball joints. Can't miss them.
Alright thanks man
top/center of this photo is a steering stop and plastic cap :great:
so you know what you're looking for http://i113.photobucket.com/albums/n...0Rebuild/5.jpg |
Thanks man i really appericiate it!
