89 pickup v6 5speed transmission stuck in reverse
Old 08-11-2010, 05:34 PM
toyocrf's Avatar
i have just bought a 89 toyota pickup 4x4 3.0 v6 5 speed manual the guy i got it from said one day all of the sudden it would not come out of reverse i took off the gear shifter and no problem with ne thing n there so i have the truck ready to take the transmission out now and was hoping to get some advice for where to look once i get it out or any tips for takin it out???
Old 08-12-2010, 12:03 AM
lukeland68w's Avatar
I have the same problem.....Im sure its the shift fork for 5/reverse, at least for my situation.
Old 02-05-2016, 03:39 PM
Yodalayhihoo's Avatar
Hello. I was wondering, since you posted a few years ago, did it end up being the shift fork? My 89 5spd, 4wd p.u. was running fine. Then it stopped liking to shift while running. Then I parked it and left it in reverse on my inclined driveway (so it couldn't go AWOL) and now it won't shift out of reverse. I thought it was a possible hydraulic problem so I replaced the M.Cylinder and slave, but nada. Also and btw, the clutch pedal won't return. Just stays on the floor til I pick it up with my fingers. Pooor sad truck needs love. But first I have to get it ready for the tow-truck. Which means OUT OF REVERSE Help!
Old 02-05-2016, 03:56 PM
MudHippy's Avatar
Unbolt the rear driveshaft. Put the driveshaft in the bed, put the nuts and bolts in the glove compartment. Off you go.
Old 02-05-2016, 04:40 PM
millball's Avatar
Uh, Block wheels first, and make sure that the service brakes are working.
Old 02-05-2016, 04:43 PM
Oh yeah, I blocked it up when I was working on the M and S cylinders. Thanks, guys. I was trying to think of what I could winch the thing to to get the weight off the gears and it was headed to sketchville. thanks again
Old 06-01-2019, 07:57 AM
Rmiller's Avatar
Did any of you figure out what the issue is, because my 94 has done the same thing!
MadMax48
03-03-2020 10:33 AM
urabus
11-10-2015 07:38 PM
irv
10-01-2015 09:49 PM
Armstrong486
09-19-2015 12:37 AM
Quick Reply: 89 pickup v6 5speed transmission stuck in reverse
