Pacesetter and Automatics
Old Aug 11, 2010 | 06:16 AM
spdjnky's Avatar
I recently purchased a Pacesetter header for my '86 22re automatic. While I was installing the header the collector kept hitting on the dipstick tube for the transmission. Instead of hammering the collector in to fit, which would have been a lot, is there a fix for this problem?
I know I ordered the right one...PU 2/4 WD, 4-Runner (4 Spd, Auto) (not column shift)
84-89 2.2, 2.4L F.I./20R, 22R, RE, REC 70-1187
Since mine has overdive would that make a difference?
Yeah I know Pacesetter sucks and I have read all about fitment isssues, but I'm still a dummy and order one anyway
Old Aug 11, 2010 | 07:21 AM
SpecialScottie's Avatar
Same thing happened to me. I used a torch to heat it up and bend it
Old Aug 11, 2010 | 07:39 AM
spdjnky's Avatar
I guess you are talking about bending the dipstick tube? I could do that or can I use a different dipstick? I have already taken the bracket loose that attached it to the transmission and bent the crap out it but it wasn't enough.
Old Aug 11, 2010 | 08:10 AM
iamsuperbleeder's Avatar
if he IS talking about bending the dip stick tube, I'd HIGHLY recommend removing it from the truck before taking a torch to if... ATF is VERY flammable once it heats up...
Old Aug 11, 2010 | 09:49 AM
spdjnky's Avatar
Gotcha! I would do that anyway, not only for safety, but it would be a good time to change the fluid and filter.
Truckwithoutaname
Oct 3, 2015 03:41 PM
Flightguy
Oct 2, 2015 05:34 PM
bradahman
Oct 1, 2015 09:24 AM
tshort48
Sep 27, 2015 01:04 PM
toyhaulert100
Sep 24, 2015 07:55 PM
