Speed Problem with my Toyota pick up
Old Aug 15, 2010 | 03:14 PM
tjbushey's Avatar
Hello, i Recently Changed the Alternator and switched from 29" tires to 31" tires and ever since i did that my speed has went down ALOT and i know the tires would bring it down but not as much as i thought it would, Dropped from top speed of 150km/hr to 120km/hr.
Is it possible if i installed the wrong alternator that the speed would drop?
Thanks and any help would be great.
Old Aug 15, 2010 | 03:26 PM
myyota's Avatar
The alternator has nothing to do with your speed, your slower now because of the bigger tires, there also heavier, and you still have the stock gears. Another thing to remember is that your speedometer is now off also, so you didn`t loose as much speed as you think you did.
Old Aug 15, 2010 | 03:28 PM
tjbushey's Avatar
thanks, thats actaully what i thought but didnt know it would change that much, i was planning on switching gears next month, do you have any in mind ?
Thanks for the help
84YotaBuck's Avatar
You do realize that your speedo isn't going to read correct with the bigger tires now don't you? You probably are doing close to the same top speed you had before, but the speedo is going to read less.
Old Aug 15, 2010 | 03:50 PM
myyota's Avatar
Thanks for the help
If your going to stay with the 31'' tires, then you will need to go with 4.88 gears to get to were you were stock. Im running 4.88 gears with 37'' tires but i also have duel cases and it works fine for me.
bigblue82
10
Jul 6, 2015 08:27 AM
Mr.Black
Jun 21, 2015 10:17 AM
kcaudill
Jun 17, 2015 08:27 AM
