1987 22rtec #3 injector problem?
Old Dec 7, 2014 | 08:51 AM
DesotoNF's Avatar
1987 22RTEC Toyota Pickup SR5 4X4 # 3 injector won't fire. Engine rebuilt, plugs, wires, cap, rotor, injectors, computer, igniter, injector plugs. Rewired the injectors up to the fender well, not all the way to the computer. I get fire on #3 plug but my # 3 injector won't fire. I can plug #1 plug from that injector into # 3 and it will fire and vise versa. It seems I don't have enough power or resistance to fire both injectors. Weird. Please Help!!
Old Dec 7, 2014 | 02:40 PM
Terrys87's Avatar
Sounds to me like it could be clogged or just not funtioning. Below the picture of the Ground wires in this thread https://www.yotatech.com/forums/f116.../#post52238808 is how I would check it. I would remove the crimps in the harness but it sounds like you may have already.
Old Dec 13, 2014 | 05:57 PM
DesotoNF's Avatar
Really appreciate all the info.Sorry i didn't get back sooner,life got in the way.Checked all my grounds,rewired my injector harness.soldered all of the connections.new injector plugs.If i unplug no.1 injector no.3 will fire,i even swaped the 2 wires coming from the resistor solenoid and still same prob (yellow and blue wires).so i,m thinking it is coming from computer end? New computer and still exact same problem so whats the odds it the computer Someone told me it mights be a ground coming from my computer might be bad but i have no idea where to check for them?
This has totally got me stumped,any help will be greatly appreciated.
Old Dec 14, 2014 | 10:57 AM
DesotoNF's Avatar
Today I tested the injectors with a noid lite. When I unplugged #1 to test it (new wiring, soldered and run all the way to the ecu for #1 & #3). With #3 plugged in I tested #1 and it checked out fine also. Number #3 will fire when #1 is unplugged. With #1 plugged in #3 won't fire, but both tested good on the noid lite. Checked Ohms on #1 and # 3 injectors, both tested good, as far as I could tell. Any ideas???? Could #1 still be bad even though it tested okay and is #1 pulling too much power from the #3? Please help...I don't know what to do!!
Doug4320
Mar 24, 2018 10:11 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
steve miller
Oct 10, 2015 01:40 AM
shar
Jul 9, 2015 12:38 PM
karbin
Jul 5, 2015 11:37 PM
