86 toyota pickup 22rte codes
Old Dec 14, 2014 | 01:29 PM
YoderTurbo's Avatar
Alright I am new to this site and would like to see if anyone can please help me out.
I have a 86 Toyota pickup 22rte I have been getting horrible gas mileage only 10 mpg. So I recently checked to see if it was throwing any codes and is currently throwing code #6 ( engine speed "rpm" sensor. And also code #14 turbocharger "tc" pressure. What would really make it throw those codes and make me be getting such horrible gas mileage? Thank you.
Old Dec 14, 2014 | 03:11 PM
thefishguy77's Avatar
I would start with addressing these components. Sensors do wear out and turbo connections can become loose. Good places to check. If the sensor is fine and the turbo and connections are fine then lets start to look at what hidden problems would cause these codes. But always start with the obvious it's just easier that way.
Old Dec 14, 2014 | 03:18 PM
YoderTurbo's Avatar
Thank you for the response will start with looking at all the connections. What sensor is the rpm sensor?
Old Dec 15, 2014 | 07:40 AM
YoderTurbo's Avatar
So I ended up changing the distributor roter and the cap, found out that I had a leak where the intake attached to the turbo cleaned all the intake a turbo ports. Took out the ecu fuse pit it back in and checked and it is no longer throwing any codes. So hopefully that will fix my problem.
Old Dec 16, 2014 | 04:17 AM
swerks's Avatar
FYI there is a site you may want to check out http://www.22rte-trucks.com
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
94hiluxZE
Jun 22, 2015 10:42 AM
