Stock rear suspension idea
Old Dec 14, 2014 | 09:19 PM
tomczaksdiesel's Avatar
Hey guys,
First time on here posting, and my first time owning a Toyota. I have a 87 pick up standard cab short bed. Its all stock with a little bigger tires. I must say that this little truck rides STIFF. It rides stiffer than my 1ton diesel to say the least...
I do notice I have a sag too. I have an idea on how I think I can get a softer ride and maintain a stock height the budget way. Now this is an idea and it may be ridiculous, but that's why I'm here for feedback.
Could I remove the thick overload spring, and add a 3 or more inch spacer block to the leafspring to make up for the sag? I seem to have stiff shocks already so I think I'll be okay there. Do you guys think that will work to achieve a smoother ride and possible more downward travel? Or am I crazy? I don't put anything heavy in the bed so I wouldn't have to worry about overloading it.I just believe the leafs now are old and resting on the overload...
Or just buy new springs.. Orrrr do what I was going to do and add on the zuk mod? I just want a softer ride with stock height.
Let me know!
Old Dec 15, 2014 | 05:33 PM
No one? I plan on trying it soon. Let me know what you guys think
Old Dec 15, 2014 | 05:49 PM
mountainbrew's Avatar
Honestly it's just as easy and cheap to do the add a leaf. I had blocks in and my bump stops would smack if I sneezed. May end up bit over stock though.
Old Dec 15, 2014 | 05:51 PM
I want a smoother ride. Won't an add a leaf cause it to be stiffer? It might be to much of a hassle. Maybe its worth just getting new rest leafs or having them refurbished?
Old Dec 15, 2014 | 10:19 PM
89pickup-pablo's Avatar
I had the same issue. I replaced my shocks and It rode better but still pretty saggy and rode hard. I recently replaced leaf springs with slightly newer ones that already had an add-a-leaf. Rides much better and sits at stock height. I would imagine the thickness and strength of the AAL has a lot to do with it. Good luck!
Old Dec 15, 2014 | 10:43 PM
RAD4Runner's Avatar
Blocks will only lift, not fix your ride quality. Yours is a common problem. Search the forum. There are many proven solutions to your problem. your choice which on to do.
Old Dec 16, 2014 | 12:53 AM
wyoming9's Avatar
Red face
If you want a smoother ride get a 4runner mine has such a smooth ride compared to the Tacoma I have to relearn how to drive it when I change vehicles.
It is a short wheel base truck meant to haul 1000 pounds in it`s day.
Perhaps new springs then do some adjusting of the spring pack to you get the ride you want.
What you call a stiff ride I might think is normal no way to really know.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
