4x4 shifter problem staying in gear??
Old Nov 26, 2014 | 06:43 PM
shepsyota's Avatar
Got a 93 pickup and 4x4 shifter wants to pop out 4h unless i hold back on it. Truck does have a 3" body lift. Whats the best and easiest fix for this??? Thanks
Old Nov 26, 2014 | 06:53 PM
JasonYota's Avatar
Well is the shifter being pushed back by the body when the drivetrain flexes? If it is just notch it where it's hitting
Old Nov 27, 2014 | 01:28 AM
wyoming9's Avatar
Red face
Before you can fix it you need to find out just what the problem is.
Is it just happening since the body lift??
Has it been happening for some time now??
It can be the shifter hitting the floor.
it can be worn bushings in the shifter.
It can be a bearing going in the transmission
Old Nov 28, 2014 | 05:09 AM
BLRobertson's Avatar
Low Range sells a Trail Gear heavy duty shift spring that helped mine a lot. My 89 has a 2" body lift and the shifter boot is putting forward pressure on the shifter lever then it would kick out of gear when I went to shift. PO had cut the boot out to keep it in gear but I wanted something besides a big hole in the floor. I have a 96 Tacoma I'm taking parts off of and the shifter boot on it was about 1" longer so I installed it which helped some but it took the new springs to keep it in gear.
Old Nov 28, 2014 | 01:40 PM
shepsyota's Avatar
Thanks for the respones. I took the boot off and found the metal had been cut, shifter was getting caught by pressure of the boot. I cut the boot and installed a universal, now shifts good. Im still gonna check out those springs at low range offroad. Thanks!!
Jnkml
Jul 6, 2015 01:20 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
zd92655
Jul 5, 2015 04:25 PM
