timing and backfiring issues, please help!
Old Nov 28, 2014 | 06:43 PM
orig89pckp's Avatar
My 89 3vze is having problems that I am just stumped on...
The problem I am having is that..
1. I CANNOT get my timing right. I have checked and had other people double check my work on timing belt alignment. the truck runs, however when I try to time it with the timing light the closest I can get is 5 degrees BTDC or 19 BTDC by moving the distributor 1 tooth either direction.
2. When running it wants to back fire up the intake. It has no power when driving
Soo with that said here is what I know.. New fuel pump, TPS is working correct, MAF is working correct. There is NO CEL codes.. not one ever and the light works. Cylinder compression is between 175-182 for all.
Any help would be greatly appreciated so I can have a vehicle running.
Old Nov 28, 2014 | 06:59 PM
rworegon's Avatar
Check all tubing and intake for a vacuum leak. A small crack can cause problems.
Old Nov 28, 2014 | 07:16 PM
orig89pckp's Avatar
All brand new vacuum lines on it. It was running and driving fine then like a light switch starting backfiring and had no power
Old Nov 29, 2014 | 08:10 AM
orig89pckp's Avatar
Update on my truck...
-Timing belt is correct, it did not jump a tooth.
-I cleaned the MAF sensor
-New fuel filter, new pump went in last night
any help would be awesome seeing im stuck with it at work.. thanks
Old Nov 29, 2014 | 08:32 AM
thefishguy77's Avatar
How long was it running and driving fine? If you put all new hoses on there then maybe one developed a crack in it. They don't make stuff like they used to is a saying for a reason. You can spray carb cleaner around your hoses and listen for the engine to race. I don't know much about the 3.0's but on the 22re. Even a very small vacuum leak will cause strange issues. Good luck keep us posted.
Old Nov 29, 2014 | 10:07 AM
orig89pckp's Avatar
it was running and driving fine for 3 weeks, and it happened like someone flipped a switch while i was driving. the hoses are thicker poly hoses. non have cracks that i can find. i used a whole can of carb/choke.. no luck
Old Dec 3, 2014 | 07:42 AM
Now when you say no CEL codes are you just looking for the light of have you jumped the ports and counted the flashes? Many codes will not trip the light. Just throwing it out there.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
colinmil
Jul 6, 2015 04:03 PM
