pitted 22r block
Old Dec 15, 2014 | 08:48 AM
tomanator's Avatar
pitted 22r block
Ok so about three weeks ago my timing chain ate through the timing chain cover on my 1987 22r. So i ordered new timing chain kit and decided replace the head gasket while i had it apart.
But after pulling the head and timing cover i decided to pull the engine and do a complete rebuild. After tearing everything apart i noticed cylinder 4 is pitted. So wanted to know should i hone it or have it bored
And please keep in mind im still in high school so money is tight, but any help is much appreciated.
thanks
Old Dec 15, 2014 | 10:33 AM
bruzer's Avatar
how bad is the pitting? id just bore it 40 over, new rings and pistons and call it good
Old Dec 15, 2014 | 10:58 AM
millball's Avatar
Get the bores measured.
Don't bore it any more than absolutely necessary to clean it up.
Just honing might be enough if the pitting is minimal.
Old Dec 15, 2014 | 02:07 PM
wyoming9's Avatar
Red face
If you were close to me I would give you a block.
You never want to remove more metal then needed .
It is not like it will give you lots more horse power in these engines.
Old Dec 15, 2014 | 04:48 PM
tomanator's Avatar
ya it's just a little i can barley get my nails in it. All the other cylinders are like glass im just tryin to spend as little as possible. And one more question how can i tell if the bearings are shot. They don't look worn but the engine has almost 250k.
thanks alot guys.
Old Dec 15, 2014 | 06:46 PM
millball's Avatar
Plastigauge
Old Dec 16, 2014 | 12:56 AM
wyoming9's Avatar
Red face
If you don`t see scoring on the bearings .
Just remember Plastic gauge needs to be done on oil free surfaces any oil at all will distort the readings .
Old Dec 16, 2014 | 08:23 AM
tomanator's Avatar
K just honed the cylinder should i do the other three? Ya still gotta clean the crank, can pressure wash it?
thanks guys.
Old Dec 16, 2014 | 08:50 AM
millball's Avatar
Ya gotta hone all the cylinders, otherwise the new piston rings won't seat.
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
shalom
Sep 8, 2015 10:02 PM
pplusent
Sep 2, 2015 11:56 PM
Fakayayou
Aug 9, 2015 12:47 AM
