93 4runner Annoying squeal
Hey guys, I'm having a problem with my rear left wheel squealing LIKE HELL between 0 and 20mph, I don't even need to be braking for it to squeal. I took the drum off and the pads look almost new and I didn't see anything wrong so I just adjusted the screw to bring the shoes in and the problem was gone until I pressed the brake pedal again so I don't know what's going on. Its a 1993 toyota 4runner 3.0 auto.
^As stated above.
Also shoes my look good but might be glazed.
Start with the basic's sand shoes, check for hard spots ( burn spots) on drum surface.
Have you driven with e-brake on lately?
Pull the shoes off and re-grease backing plates.
I haven't driven with the ebrake on, I was g going to clean and lube everything and see if that helps, the right shoe was rough at the bottom and it felt like sand paper.
Okay so update on the truck, I replaced the hardware shoes and cylinder but now the brake light is on and fluid isn't going to that wheel so u have no brakes on that wheel. What do I do?
Flying91
45
04-11-2024 04:39 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
