Redline MT-90 Tranny question
Old Nov 28, 2014 | 05:08 PM
djtroy's Avatar
Well I bought the truck and had some issues with smooth shifting. On the recommendation of this site I ordered a few bottles of mt-90. I dumped it in and noticed a definite improvement but once it gets warm and I have to shift down into 1st or 2nd the gears still grind a bit. I did notice when its cold outside or the truck is not hot yet it shifts perfect.
I was thinking perhaps there was a thicker fluid I could use for this warm Florida weather that would work like when its cold outside or the truck is cold.
Old Nov 28, 2014 | 05:17 PM
RustBucket's Avatar
Sounds like the synchros are just a bit worn. Does double-clutching help the grind?
By putting a thicker fluid in it you may compromise adequate lubrication of everything else, kind of like putting SAE50 into a worn motor to damp out the clatter.
Give the MT-90 a little time or try Amsoil MTG, both are excellent and exactly what your trans wants to operate well.
Old Nov 28, 2014 | 05:20 PM
djtroy's Avatar
Yeah is this something that might get better with time? I replaced the bushings on the shifter and also took the play out of the clutch. Its not horrible but damn the thing shifts so good when its cold. I can shift down with no issues even into 1st gear. Just thought maybe I could get something different in there that works in this heat.
Old Nov 28, 2014 | 06:16 PM
thefishguy77's Avatar
Let it work it might get better. Stupid question are you rev matching on your down shifts? If not that will help you down shift a lot smother. Hope this helps
kazuya2416
Apr 5, 2024 02:17 AM
Dieselmann
Feb 19, 2019 02:57 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
