1994 4Runner Wiring Harness
Old Dec 18, 2014 | 08:40 PM
lorikcarroll's Avatar
I am new to this site and am looking for a 1994 4Runner Wiring Harness. I have run in to the issue of whether the automatic transmission harness is compatible with the manual transmission harness. Also, the engine is the 3.0L and are any other year engines compatible. Thanks for any help.
Old Dec 19, 2014 | 12:20 AM
wyoming9's Avatar
Red face
Hi Welcome To Yota Tech!!
Just what harness do you need there are a few in your vehicle.
What are you trying to do convert from Auto to manual??
I would spend some time reading on just what you want to do.
Then ask more detailed questions .
I doubt Toyota still has the wire harness for that year so perhaps someone parting out a vehicle on here or used are your only sources.
Old Dec 19, 2014 | 06:48 AM
1994 4Runner Engine Wiring Harness
Thanks for the response wyoming9. I guess I was a bit unclear. We are taking the engine apart due to a blown head gasket. The current engine wiring harness is in terrible shape so I am looking for one to replace it. My question about the transmission was only to determine if the harness I found for a manual transmission will work on the auto transmission that I am working on. I did find a new one at an auto dealer but it was very expensive. As a result, I have been looking for someone parting out and have located a couple, one being for a '93, thus the question about compatible years, and the other being a manual transmission. Thanks again for the help.
Old Dec 19, 2014 | 02:55 PM
Terrys87's Avatar
On a manual transmission truck there are 4 harnesses. Main Harness, Injector Harness, Head Light Harness and the Fuel/Tail Light Harness. I am not sure on the automatics. What I do know on the automatics, just under the cover and in front of the shifter, there is a little computer like box that is somehow involved with the automatics.
If I am understanding your question right, I would say no on the manual harness to the transmission. I am sure the injector harness would work if that is the one you are talking about and the injector harness is usually in bad shape from my experience and that is on the 22re.
Old Dec 20, 2014 | 04:14 PM
4x4YOTA's Avatar
I have most of my old engine and transmission harness from my 94 auto I did a 3.4 swap so it is a mess but I only cut out the interior to engine plugs off
let me know what you need
Old Dec 21, 2014 | 07:44 AM
'94 4Runner Harnesses
Thanks Terrys87 and 4X4YOTA for the info. If anything, I am learning alot about 4Runners and specifically my '94. I would love to have the engine harness from you 4X4YOTA. How much do you want for it and how can I make that happen? We are having the heads machined and a valve job done right now. Since it is Christmas next week we probably won't do much work on it then. I will check with my mechanic and see if we might also need the transmission harness. Thanks again everyone.
Old Dec 23, 2014 | 08:07 PM
4x4YOTA's Avatar
I will get some pics of the harness this weekend and see if you can use it and if you want it just pay shipping and I'll send it to you
Old Jan 9, 2015 | 05:18 PM
Thanks 4X4YOTA. I would like to see a picture of the engine wiring harness to see if that is what we need. Looking forward to the picture.
Regency
20
Jan 3, 2020 07:43 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
