Auto trans questions
Old May 14, 2008 | 07:26 AM
ratfink92's Avatar
Heres the problem, Sometimes my 92 runner wont shift into second gear it acts like its in neutral cold, hot it doesnt matter. I would say the second gear band needs to be replaced but 60 percent of the time it shifts just fine. Yesterday it started randomly hunting for gears at 55mph 3rd to 4th convertor locking and unlocking. Weird. Do you guys think it maeby the soleniods are sticky?Is there a computer glitch? A vaccum problem? How do i tell for sure? Also my speedo quit working not sure if thats related.1992 4runner 3.0 auto 4wheel drive.
Thanks
Old May 14, 2008 | 07:39 AM
ratfink92's Avatar
By the way trans fluid looks good not burnt and full.
Thanks again
Old May 14, 2008 | 12:40 PM
ratfink92's Avatar
bump............
Old May 14, 2008 | 01:03 PM
4runnerx3's Avatar
There are 3 solenoids. 1 and 2 shift and torque converter lock. 1 & 2 work in on and off sequences together. If they fail mechanically, you will not get a code.
Old May 14, 2008 | 01:09 PM
ratfink92's Avatar
thanks for the reply. I have no codes. Anyway to say for sure its the solenoids? Can you dissasemble and clean them?
Old May 14, 2008 | 01:13 PM
4runnerx3's Avatar
It may be a pressure problem these seals can cause problems.
you can pull them out and check them.
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
the1998sr5
Jul 16, 2015 06:20 AM
andrewtexas123
Jul 14, 2015 04:29 AM
KBar
Jul 13, 2015 06:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
