Have code 71 so I..........
Old May 18, 2008 | 12:39 PM
94toy4x4fever's Avatar
I went out today and applyed vaccum and suction to EGR and nothing happend! So Im going to buy a new one! Also I have the check engine light which is how I found out it was the EGR. Now I cant get the light to go off by pulling the EFI fuse! Can I just pull an battery cable off to clear the code?
Old May 18, 2008 | 01:03 PM
scuba's Avatar
pull the battery for ten mins. it will go off
but might come back soon. esp if you havent fixed the problems yet
Old May 18, 2008 | 01:06 PM
abecedarian's Avatar
There is a chance that the code shows up as soon as you turn the key on (particularly if the EGR sensor has failed). In that case, resetting the code by removing the fuse or battery isn't going to make it go away until the problem is fixed.
Old May 18, 2008 | 01:46 PM
were is the egr sensor? Are you talking about the valve?
Old May 18, 2008 | 02:44 PM
js9924's Avatar
there is a temp sensor in the side of the EGR has two wires coming out
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
