been looking cant find exact info? 15 x10
I have the opportunity to purchase 4 white rims 15X10. The seller does not know of the back spacing, I plan to run 32 inch tires. I was just wondering if anyone has run this setup before. As well, I like to know if there are any drawbacks if its a 3.75 or 4.75 backspacing with that size rim? anyone?
im pretty sure you measure the backspacing by putting a straight edge across the rim and measuring the back of the mounting flange to the straight edge. maby you could have him measure them for you?
Yeah, that's how you measure it.
Here's the thing - I assume you're talking about a 33x11.50. And I assume this rig will actually see offroad, otherwise you'd go for something a bit more bling than white rims.
1.5" difference between the rim width and the tire width is no bueno. You WILL take a lot of rim damage offroad. In other words, a 10" wide rim is only good for tires wider than 12.5 inches.
the1998sr5
15
07-14-2020 08:35 PM
skoti89
09-11-2015 07:46 AM
Jeffreynmandy
07-18-2015 08:26 AM
88yodabasket
07-13-2015 01:32 PM
