22re electric fan
Old May 20, 2008 | 05:23 PM
Hayes's Avatar
22re electric fan
I have an engine I am getting ready to put in and want to get an electric fan to install at the same time. What should I know about picking a fan to use?
"Electric Fan, Single, 16 in. Diameter, Reversible, 2,010 cfm, Black, Plastic,"
Does this look like a good deal? What should the max cfm be? Size? Any info would help.
-Hayes
Old May 20, 2008 | 05:28 PM
4Crawler's Avatar
I used to run a Flex-a-lite #165 and it was adequate, 2200 CFM:
- http://www.flex-a-lite.com/auto/html/toyota-4x4.html
Old May 20, 2008 | 05:30 PM
bigt's Avatar
also ford tarus form a junkyard 90s are good fans..im gonnna look for one next time i go to the junkyard
abecedarian's Avatar
Hayes- the biggest problem you'll have with that fan is that it does not pull air across the entire radiator, but only across the area covered by the fan itself. If you really wanted to make it work, you'd need to space the fan off of the radiator and extend a shroud out to each edge of the radiator so that air is pulled across the whole thing. Otherwise, you'll end up overheating at idle / low speeds.
Old May 20, 2008 | 06:08 PM
seafarinman's Avatar
get an electric fan from a 3.8l Ford Taurus, or Mercury Sable, or a Lincoln MKVII... and then look up my Taurus fan writeup on this site.
coryc85
Sep 9, 2015 06:24 AM
jackiebrownia
Jul 20, 2015 09:02 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
1996Taco
Jul 20, 2015 12:02 AM
zd92655
Jul 5, 2015 04:25 PM
