33x12.5 rub?
Old May 16, 2008 | 07:51 AM
Trustyrusty's Avatar
33x12.5 rub?
Hey If I get a 2" Toytec lift could I run 33x12.5x15 without rubbing at all? What backspacing would I need? I'm either getting the toytec lift which is BJ Spacers and AAL, or Shackles in the rear.. Which should I do? Shackles or AAL? I'm getting Pro-Comp shocks also.. Just wanted to know if it would rub or not, If it rub's I'll do some pounding and a small BL..
Old May 16, 2008 | 07:58 AM
4Runner202020's Avatar
yes they will rub. get the 3in with probably a 1in body lift and you'll be good. and get 3.5 to 3.75 in backspacing for that wide of a tire to clear the a-arms.
Old May 16, 2008 | 08:00 AM
4Crawler's Avatar
You'll find some lift and tire/wheel size information on the web page below:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old May 16, 2008 | 06:42 PM
FredTJ's Avatar
If they're going to rub because of height, that is on the underside of the fenders during stuff, then it's not really going to matter how much suspension lift you add, without lowering the bumpstops, they'll still rub.
The body lift, though, will help.
Fred
Old May 16, 2008 | 07:15 PM
Blackulua's Avatar
My truck is a 1988 4wd std bed.I have a 1" RB body lift,BJ spacer,longer rear shackles,33 x 12.5 tires on MT Classic II 10"wide x 15" wheels.Everything clears no problem from the front maybe just a slight front valence adjustment but no rubbing issued around the front fenders.
Old May 16, 2008 | 07:34 PM
TomkiRider's Avatar
I have 33x12.5s not sure how big my lift is but the tires rub pretty good when you crank it all the way
Old May 16, 2008 | 07:46 PM
FredTJ's Avatar
When you turn hard, is that what you mean ?
If so, that's mostly a backspacing issue with the wheels, too much backspacing.
Fred
Old May 16, 2008 | 08:07 PM
TomkiRider's Avatar
what else would that mean?
Old May 16, 2008 | 08:16 PM
FredTJ's Avatar
Hard to say for sure from you "Boonies" people
Fred
Old May 16, 2008 | 09:03 PM
TomkiRider's Avatar
lol guess i had that one comin
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
matt1833
Sep 16, 2015 07:11 AM
langry345
Sep 14, 2015 03:36 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
