turbo motor
Old May 20, 2008 | 12:20 PM
weaselman's Avatar
Exclamation turbo motor
what do you guys think would happen if i took the turbo off of an 87 22re turbo 4runner and put it on an 86 22re non turbo 4runner. without doing anything much else...
Old May 20, 2008 | 12:31 PM
camo31_10.50's Avatar
im not sure you would see much of an improvement....but if you swaped the heads...pistons...new cam...intercooler...allllll that...u would see probably close to 150hp
Old May 20, 2008 | 12:32 PM
gilby4runner's Avatar
I believe there would be to much compression for that set up. I know the turbos run a lower compression. Also wouldnt it run lean?
Old May 20, 2008 | 12:39 PM
iamsuperbleeder's Avatar
Yeah, you can't just slap a turbo on a non-turbo setup long block and call it a day. Hey, it may fire up and run, but it won't run very well, not to mention it wont run very long.
Old May 20, 2008 | 12:49 PM
cutboggers's Avatar
It would work if you swapped the injectors(maybe injection) also. Like above though your comp could be too high, but i am not sure. I know you can buy a turbo aftermarket bad boy for your stock 86 so i don't see a problem with compression. prob just create a lot of boost out of a low boost turbo.
you will also have to drill and tap the block for the turbo set up....(oil lines)
Old May 20, 2008 | 12:56 PM
cutboggers's Avatar
Old May 20, 2008 | 05:18 PM
just a 22re's Avatar
oil lines are the easy part run a tree on the oil presure sencer and drill a hole in the pan done but as far as comp youll be fine think of the honda girls that do it all the time but fuel is going to be your brick wall you cant use a
SAFC on our trucks trust me i've tried many times but if theres away then you can use all the stock parts!!!!!! EVERYTHING from this doner truck
Old May 20, 2008 | 05:24 PM
Hayes's Avatar
keep the boost at a modest level and you will have some fun. Stock turbo engines are only 130 something power...so you won't feel much of a difference.
Old May 20, 2008 | 07:15 PM
dcg9381's Avatar
You might be able to bolt it up, keep it under 3-4 psi and see it live for a while. If you go lean, it's going to make a big mess.
You don't need to drill and tap the block for oil lines. There are other ways to do it.
With a 9.4:1 compression motor and a turbo, I made (flywheel, not rear wheel): 169 hp, 244 ft/lbs torque. That's tuned - not going lean, and 93+ octane fuel.
Beyond 10psi I had real trouble getting any additional power.
E85 helps a bit, but at the cost of MPG.
Old May 20, 2008 | 07:16 PM
scuba's Avatar
stock turbo was 150 i believe
Old May 20, 2008 | 07:26 PM
Hayes's Avatar
135 horsies
Old May 21, 2008 | 07:35 PM
weaselman's Avatar
awsome. thanx for all of the input guys i appreciate it.
maybe working on my truck will help me forget about all my problems. ugh.
Old May 21, 2008 | 07:39 PM
abecedarian's Avatar
yes...
... sigh ...
I find myself ...
and ... my problems find me too ...
... somewhere between ...
me ...
... and my truck ....
God's Bounty Hunter
Oct 23, 2015 09:44 AM
RatOmeter
Oct 22, 2015 03:17 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
karbin
Jul 5, 2015 11:37 PM
