leave the C Clip out?
Old May 19, 2008 | 04:55 PM
n16ht5's Avatar
Im putting my hub back together... can I leave off the C clip to make CV changes easier? Mine doesnt have much play, and stays in the same place pretty much all through the up and down susp travel...
Old May 19, 2008 | 05:03 PM
INFINITY's Avatar
i would put it back in...removing the c-clip when you take your hub off is a lot quicker than replacing the brass bushings in the spindle.
so put it back in. you shouldn't be opening up your hubs that often unless you are changing a cv axle.
Old May 19, 2008 | 05:18 PM
fillsrunner4's Avatar
I would not leave them out aseptically if you have some. Put um back in and carry snap ring pliers
Old May 19, 2008 | 08:43 PM
n16ht5's Avatar
ok. I have them, but I bent one taking it off :-/
time to start carrying snap pliers.
Old May 19, 2008 | 08:45 PM
TOYOTA 1's Avatar
x2. when that brass goes bad you get a nasty grinding/vibrating sensation.
Old May 19, 2008 | 10:41 PM
n16ht5's Avatar
I wonder if I could make up some sort of c clip elim.... like a washer that goes on the drive flange (ADD hub) underneath the brassy washer - bolt (on the end of the axle)
that would hold it out and in place, and wouldnt have to worry about watching those c clips go flying in the mud/snow
Old May 19, 2008 | 11:42 PM
tc's Avatar
tc
Go and get a real snapring (with the holes for the snapring pliers) instead of the damn circlip/snapring - will make it a million times easier!
Old May 25, 2008 | 07:10 AM
n16ht5's Avatar
i machined out some washers to eliminate the c clip the other day, works great.. ill post up pics soon
live4soccer7
May 11, 2016 06:52 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
the_supernerd
Oct 1, 2015 09:20 PM
dbollier123
Sep 29, 2015 05:23 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
