IFS rebuild
Old May 15, 2008 | 11:51 AM
js9924's Avatar
IFS rebuild
I am going to be rebuilding my IFS and buying the wabfab 2" lift kit with the AAL and the BJ spacers. I also want to replace the ball joints and the tie rods. I have rack and pinion and all the kits I can find are for the older linkage style.
So does anyone know where I can get all 4 ball joints and rod ends? Reliable? OEM or aftermarket?
Any advice will be appreciated but please dont suggest SAS because its only 2wd and I dont have the money or desire to do an SAS.
Thanks
Old May 15, 2008 | 12:37 PM
norcalsvx's Avatar
i rebuilt mine with napa parts (moog i think) check your local place
Old May 15, 2008 | 01:25 PM
js9924's Avatar
how about this kit from ebay item# 140158906127 cant beat the price
Old May 15, 2008 | 02:37 PM
86Original's Avatar
Or you could do it right (IMO) with genuine parts from ToyotaPartSales.com. That's what I did...
Old May 15, 2008 | 08:01 PM
Bear80's Avatar
Some of the cheap TRW boxes from Advanced Auto Parts will contain "555" brand parts which are made in Japan. This is the only brand I will use other than oem for steering or suspension parts. I would assume the ebay stuff is China made, possibly not bad but the quality control of Chinese made parts don't have a good track record.
Old May 15, 2008 | 08:16 PM
Zona4r's Avatar
rockauto.com
Great prices and great customer service. I went with Spicer professional BJs and control arm bushing and was happy to see all were made in Japan and not China.
Old May 18, 2008 | 10:34 AM
js9924's Avatar
Im gonna ask the guy where they are made I can get the whole kit for what the dealer charges for one rod.
But I guess you get what you pay for.
Old May 18, 2008 | 10:41 AM
4x4phil's Avatar
how much is that kit?
I can't get on to e-bay here at work.
I need to rebuild half my suspension, I figure why not all if im in there
Old May 18, 2008 | 02:55 PM
js9924's Avatar
The kit is $100 plus shipping but I emailed the guy he says they are O.E. parts made in china. So I dont think ill be getting them. Here is the item number again 140158906127. Rockauto.com doesnt have the right inner rod for the rack and pinion(maybe they do but not under the 94 T100 dlx, im gonna call them on monday ill let you know. but they have japanese and american made parts for less than the stealership. Looks like ill be putting this off for a while til I can afford to do it right.
Old May 20, 2008 | 10:00 AM
86Original's Avatar
Have you checked with strap22 & trdparts4u (members here)? They work at toyotaPartSales.com and usually have very good prices on factory parts. It's definitely worth checking... For almost everything, I've quit buying 3rd party parts and just buy from them...
Old May 20, 2008 | 12:54 PM
js9924's Avatar
I checked the site and the prices are insane they want $113 for one inner rod. I understand there is a warranty on the parts and they are factory certified and all that but that does not justify the price being 10 times what I can get it for other places. Especially considering these parts are meant to be replaced every few years depending on use. Thanks though.
Old May 20, 2008 | 01:21 PM
DaveInDenver's Avatar
For my truck ('91, 4WD, 22R-E), the inner tie rod from Toyota lists for $49, outer $46, adjusting tube is $18. So most online dealer parts places will be about $35 for the tie rod ends and $12 for the adjuster. The relay rod or center link (the part replaced for free under the recall) lists for $155, which is usually quoted for about $113. That does not wear out and does not get replaced periodically like the rod ends. Ball joints from Toyota list at $63 and quoted at $46. That's as cheap as NAPA for an equally good part.
Old May 20, 2008 | 01:29 PM
4Runner202020's Avatar
long travel it while your at it. that would be sick considering its a 2wd
Old May 20, 2008 | 09:00 PM
js9924's Avatar
ok again my truck is rack and pinion dave yours is not so it is cheaper. It is the inner rod that is $113 it threads into the linear gear that connects to the pinion. Very different from your linkage type steering.
Please read the post before you respond I have said several times that it is rack and pinion.
Not being rude but it seems people will reply to a post before they have even read it.
Old May 21, 2008 | 04:01 AM
Yeah, my mistake, work has been really long days. So I was rechecking with the right truck...
The NAPA catalog doesn't seem to say specifically, but it does sort of look like there are TREs for both rack & pinion and conventional. Have you gone in and matched them visually? The inner TREs on the two systems is a lot different. Isn't the inner TRE inside the rack assembly? I'd be skeptical if there's that much difference, it always seems the part through Toyota is much closer to the NAPA price than that.
Old May 21, 2008 | 09:26 PM
js9924's Avatar
no worries it happens alot here.
Anyway there is a ball/socket joint which I think is the reason for the high cost of this part. The rod has a ball on the end and the socket end is threaded and goes into the rack assembly.
Old May 22, 2008 | 03:29 AM
Yeah, that's what the diagram looked like. When you get 90% as good (or maybe better) part for a lot less, no reason to stick with them. Like you say, if it's strong enough, ball joints and TREs wear out anyway. Good luck, back to lurk mode just following the thread.
Old May 23, 2008 | 09:36 AM
js9924's Avatar
honestly Im gonna get rid of it and get a 4 runner. there just isnt enough seating in the t100. if someone wants it I just rebuilt the 3.0 with all factory parts A/C is cold and it has wide wheels. wanna see some pics of it click on the link in my sig im in FL.
pickle6415
Oct 19, 2015 08:08 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
icentropy
Sep 10, 2015 05:03 AM
--Oz--
Sep 6, 2015 01:06 AM
TOYROX
Sep 4, 2015 06:02 PM
