heli coils
Old May 13, 2008 | 04:40 PM
toyotatom93's Avatar
heli coils
Haw hard or easy are these things to install?
Old May 13, 2008 | 04:50 PM
RobD's Avatar
Pretty easy. Drill, tap, install Heli-Coil. Don't over tighten. Go to Lordco and grab the right size. I had to use them on my slave cylinder when I pulled my motor, as I twisted the heads right off the bolts holding it on. First time using them and they're fine.
Nice pic. You missed by 10 kms.
Old May 13, 2008 | 05:02 PM
abecedarian's Avatar
Yep. They're pretty danged easy. If you buy the kit for the bolt size you're installing you get a drill bit to drill out your existing hole, a thread tap to use to cut new threads for the helicoil and the helicoil insert to do the job.
Just make sure to install anti-sieze lube on the bolt.
DanStew's Avatar
They are not hard to do, just take your time. And on aluminum use lube ( i learned the hard way) and use some compressed air to help clear the aluminum slivers, cause if they get stuck to the tap they will round or flatten the threads you are cutting
Old May 13, 2008 | 05:18 PM
Cool, thanks guys. Although I am a little worried about drilling my spark plug hole. Damn PO
Old May 13, 2008 | 05:27 PM
RobD's Avatar
You'd be best to pull the head if you could. Otherwise, and this is just the advice of a complete stranger, but make sure you use grease on the tap to collect the shavings if you're not going to pull the head. Clean it frequently so they don't end up in the cylinder.
Old May 13, 2008 | 05:40 PM
corax's Avatar
Don't use a heli-coil. For spark plug thread repair, use a Time-Sert. I can usually find them at PepBoys or Autozone, but most parts stores should be able to hook you up or special order a kit
http://www.timesert.com/html/sparkplug.html
instead of wound wire to replace the threads, it uses a solid sleeve. the bigger threads are cut with a stepped tap that uses what's left of the original threads to get started (no drilling) the trick is to put grease in the tap flutes to collect aluminum chips and back the tap out to clean and regrease the flutes
Old May 13, 2008 | 05:46 PM
Well... now you're saying it's a spark plug hole that's fubar'd.
As RobD mentioned- lube that tap. I'd say lube every 1/8 turn in and back it out 1/2 turn and vacuum out every little shaving you get- keep that vacuum running all the time you are backing the tap out.
Old May 13, 2008 | 08:54 PM
Ya guess I should have mentioned it was a spark plug hole.
The time-serts look like a better product, but I still gotta drill...oh well guess I gotta just give er.
Old May 13, 2008 | 08:57 PM
lol ya I was waiting for so long to set it properly but of course I forgot to look at the moment of truth.
Old May 13, 2008 | 09:19 PM
reggie 00's Avatar
Don't sweat the spark plug hole.
Just do like everyone said and use grease and take your time.
What little bits of metal that does find its way into the cylinder will either be burned up from the pressure and heat of blown out during the exhaust cycle.
I had to do this same repair really fast on a Honda so i could make it back to the airport to catch my flight back so i wouldn't be AWOL.
I just reamed the thing out dry, ( i was pissed it broke in the first place)put in the insert they gave me for spark plugs and jammed a new plug in. never a problem.
Old May 13, 2008 | 09:36 PM
corax's Avatar
You don't have to drill with the TimeSert. Here's the directions
http://www.timesert.com/html/howtosp.html
Old May 13, 2008 | 10:11 PM
well look at that, I was just on the site and saw a vid on how to install and they drilled it...this is much better, thanks.
Holy crap the timesert kit is expensive...
Old May 13, 2008 | 10:52 PM
corax's Avatar
look around a bit. I can't find it on the PepBoys site, but I found a knock off kit there that works exactly the same for around $30 just a year or two ago.
Old May 13, 2008 | 10:56 PM
kd's Avatar
kd
wow, i thought i was going to have to buy a new cylinder head. this just happened to me too.
Old May 14, 2008 | 12:03 AM
Matt16's Avatar
Imagine if you paid for someone to do it for you. I don't think I'd worry much about aluminum shavings. Its pretty soft- compare drilling aluminum vs steel. or cast iron. Aluminum also burns easy enough.
Old Apr 13, 2009 | 07:02 AM
gametom's Avatar
Has anyone tried this kit http://www.amazon.com/Perma-Plug-1-2...591027&sr=1-24 i have the same problem i found this online since all i can find local is heli-coils. i have an advantage tho the head is off the block.
MadMax48
Mar 3, 2020 10:33 AM
Corvoid
Dec 11, 2015 11:21 AM
the_supernerd
Oct 1, 2015 09:20 PM
mojo4x420
Sep 16, 2015 08:07 AM
