Future ideas for the '86....
Old May 19, 2008 | 08:55 PM
thook's Avatar
Howdy gentlemen...
I was thinking this summer, when I get around to doing some rust work that entails lifting the body off the frame for the job, that I might do a mild body lift for ease of maintenance purposes on certain jobs. I'd consider ramifications of coolant lines, motor position, tranny/t-case position, shifter, etc, etc. So, then I thought why couldn't I also lift the whole motor and drivetrain tucking everything upwards with the body. Might bypass the issues mentioned here. Possibly? If it's doable, how would that be accomplished? Blocks at the motor mounts, a raised crossmember? And, how would this affect pinion angles and u-joints? Bad? Good? Any input?
Thank ya for any replies!
Old Jun 5, 2008 | 03:39 AM
thook's Avatar
Bump spelled backwards means nothing....
Old Jun 5, 2008 | 03:50 AM
Workhorse's Avatar
http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
drivetrain lift by 4crawler
Old Jun 5, 2008 | 05:12 AM
thook's Avatar
Ooooh, that's fantastic. Thanks!
edoyle12
11
Mar 20, 2017 02:26 AM
94ofCanada
Aug 14, 2015 06:37 AM
corey519
Aug 12, 2015 11:12 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Bawlzdeep
Aug 2, 2015 08:35 PM
