Power steering pump questions
Old May 18, 2008 | 11:35 AM
Jay351's Avatar
Okay, so after having my power steering pump pully come OUT of the pump and almost into my fan the other day, I have installed a used pump I bought last week.
I got everything hooked up like its supposed to be but I have a question or two for you guys..
First.
when I removed the old pump, a little fluid came out of hte lines.. Nothing major, perhaps 1/4 a quart. It did dump some fluid out when the pulley came out of the pump the other day. Can I assume there is still some fluid inside the system?
Second.
Can I just fill up the new (used) pump, install my belt and call it good?
Or should I jack up the truck, and cycle the steering from lock to lock a few times then check the fluid again?
I really don't know much about the power steering stuff.. Just how it bolts in
Thanks guys (and girls)
Old May 18, 2008 | 11:59 AM
abecedarian's Avatar
you don't necessarily have to jack it up, but do cycle the steering back and forth from lock to lock and hold it a few seconds at each lock. That should purge the air from the system. check the fluid in the reservoir after each left/right cycle so that you don't risk introducing more air into it.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jon.r
Jul 11, 2015 03:34 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
