vacuum ports rusting on intake manifold
Old May 13, 2008 | 11:09 PM
kd's Avatar
kd
like the title says the vacuum ports on my intake manifold are rusting and breaking is this a common problem? what can i do short of getting a new manifold?
Old May 14, 2008 | 05:28 PM
thook's Avatar
Common? I don't know about that. I can tell you I've not had that problem myself.
Some of them thread in and out and can just be replaced. But, for the ones that don't.....well, it might be time for a new manifold.
On the other hand, I am thinking you might able to find some of the same size as the ones that are rusting (that are part of the manifold) that would thread in and out, cut the rusted ones off flush, and tap the manifold to replace with the ones that thread in, but I don't know how reliable that would be.
What motor are you having the problem with? I have a used V6 manifold I could sell you......cheap.
Old May 14, 2008 | 07:01 PM
iamsuperbleeder's Avatar
22re manifolds are aluminum are they not? how would they rust?
don't know about the 3.slow though.
Old May 14, 2008 | 08:43 PM
Green93's Avatar
The 3.0 manifold is aluminum as well but it does have a bunch of vacuum lines bolted to the underside of it that could rust. They are a separate piece that could be replaced though. Or if you just need a quick fix, you could just extend you're rubber vacuum lines since the metal piece is just a neater way of transferring them from one side of the engine to the other. Sorry can't find a pic of those hard lines. Maybe someone on here has one.
Jason
Old May 16, 2008 | 11:27 AM
kd's Avatar
kd
its a 22re and yes the aluminium intake mani dosent rust, but the steel vacuum and small coolant ports that seem to be pressed or brazed in do rust and thats my problem. ill probable just buy a new manifold. it just sucks because these things are such a pain to take off but oh well
Old May 16, 2008 | 12:08 PM
thook's Avatar
If you would be interested in a used one, why don't you check the YT marketplace for folks parting out?
Blamalam
Mar 12, 2022 07:34 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Poppie51
Jul 23, 2015 05:03 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
87blyota
Jul 10, 2015 04:31 AM
