saggin in the rear
Old May 13, 2008 | 08:43 AM
yota4life6's Avatar
saggin in the rear
Hello again... I just purchased a 95 Toyota 4Runner 4x4 and as most do, it has the notorious rear end sag going on...... Can someone help me and tell me the least expensive way to raise the rear back to level? I have heard a few different ways but nothing in detail.. My buddy has a 69 mustang that sagged and he put some air adjust shocks to the rear and can raise and lowere to any level very easily...I like that idea but havent had any luck finding the pair that fit...Any suggestions?
thank you much
Old May 13, 2008 | 08:46 AM
UKMyers's Avatar
Not the cheapest but the proper way to do it
https://www.yotatech.com/forums/f128...4runner-76341/
Also I'll tell you what I tell all the noobs check out the search feature. A quick search for the word sagging yielded 888 threads in less than a second. This topic has been discussed many many many times.
Old May 14, 2008 | 07:17 AM
yota4life6's Avatar
thanks for the link and helpful hints!! Much appreciated!
Old May 14, 2008 | 08:20 AM
dropzone's Avatar
Fossilized
Welcome to the wonderful world of Toyota Saggy butts. I have had 5 Toyota trucks over the last 22 years. My first, an '86 4Runner I purchased new sagged with in a year. Toyota has never gotten the springs right on the their trucks. My beater tercel seems to be ok though--go figure...
Good luck with your 4Runner and welcome to YT...
Old Jun 10, 2008 | 05:04 PM
yota4life6's Avatar
hey guys-
I am looking into airbags for my rear suspension.. I have been told they handle well and FIX THE SAG in the rear... I am loking at the AIRLIFT 1000 kit, pretty inexpensive compared to other alternatives. CAn anyone verify I Will get a couple of inches lift with inner coil airbags?
thanks as always
neal
Old Jun 10, 2008 | 05:14 PM
76ANTHONY's Avatar
Originally Posted by yota4life6
hey guys-
thanks as always
neal
thats what i have in mine and it works great...at 80 bucks or so you cant beat it, takes a little to install but a 6 pack of beer and a couple tools and you'll get it....
Old Jun 10, 2008 | 06:28 PM
86blue4runner's Avatar
hey guys-
thanks as always
neal
you could always do what i did and get new shackles, actually i just ended up getting only the plates and rebuilding mine with the longer plates. www.wabfab.com go there and check them out. much cheaper and easier to do. $28 shipped for the 6in shackles wich is probably what you need.
Old Jun 10, 2008 | 06:47 PM
Godzilla's Avatar
He has a 2nd gen 4Runner which has coil springs in the rear, not leafs.
As for the sagging rear. Throw in some Downeys or OME's and call it a day. Air bags are a good choice for some depending on your vehicle use.
Old Jun 10, 2008 | 07:04 PM
Fink's Avatar
x2 on both points.
This topic has been discussed more times than any of us would like to even think about.
I got the Downey's on my '95 ages ago and they were awesome...couldn't have asked for a better setup.
Fink
Old Jun 10, 2008 | 07:10 PM
wow. i just now caught that. my bad.
Old Jun 10, 2008 | 07:18 PM
thook's Avatar
I've wondered how the air bags work as a long term solution. I mean, they were designed to offset heavy loads....relieve the coils of the heavy stress....but, only under those temporary conditions.
How long have you had yours and do you have them inflated 100% of the time?
Old Jun 10, 2008 | 07:22 PM
yakamoto1988's Avatar
That would be SWEET to see some shackles put on a 2nd gen. 4runner LOL
Old Jun 10, 2008 | 07:28 PM
stupid_mud_gremlins's Avatar
I threw firestone "air-mount isolators" in (part #w01-358-3400). They're basically a heavy duty air spring meant for holding up vibration sensitive equipment. As such you can tune your ride by adjusting the pressure in your bags(adjusting the pressure changes which vibration frequency is attenuated and how much). It's only been in about 2 months now, so I haven't had much playtime with them, but I've had them off-road quite a few times (through the mud to the fishing hole, and some really light rock crawling) As someone suggested above, you notice the biggest difference when it's loaded, 35 lbs of air hauling 6 bags of grass(about 60 lbs a piece), a lawnmower(about 70 lbs), power rake(upwards of 200 lbs) , and all the other lawn tools I could fit in the back(75 to 100 lbs), and it feels like you're driving around on pillows. If i remember right the rear end (leafs don't forget, it's an 89) cost me in the neighbourhood of $600 or so, but I work at a distributor for the air-mounts.
Old Jun 10, 2008 | 09:20 PM
76ANTHONY's Avatar
I'VE had them 2 years and the guy before me had them for about 4 years, i keep them at 75 psi and they dont leak at all, the work really well. i've deflated them to 30psi and didnt like the saggy swaying rear end.
Old Jun 11, 2008 | 07:40 AM
nateW6777's Avatar
I have the airlift 1000 kit and it works great! They've been on for 6 months and haven't lost any air - no sag. Pretty inexpensive route - compared to new coil springs.
Old Jun 11, 2008 | 09:14 AM
Alex 400's Avatar
I just threw coils from all pro off road and they are reallly awesome. very consistant. I also put on some new shocks. Deosch Tech mv-12's. Rides great, really like it.
Old Jun 11, 2008 | 09:20 AM
qdude79's Avatar
I put some spacers in there (1.5") so I could retain my stock ride. Ordered air shocks to fit for heavier loads and when pulling my bike trailer. Haven't tried 'em yet, as the front end is under the knife. It was cheap and easy, once you wrestle the spacers in.
Old Jun 11, 2008 | 09:35 AM
rusche's Avatar
I'm running a 1'' block for the time being.
Dont be like me
I'm only doing it temporarily because rebuilding the engine has made it tough to be able to afford new springs
Old Jun 11, 2008 | 04:59 PM
qdude79's Avatar
To give a little before and after, check this pic compared to my avatar...
PS- Don't pay attention to the cheesy rollers it's sitting on...
Qdude
Old Jun 12, 2008 | 12:10 PM
yota4life6's Avatar
nice!! how does it ride with the spacers? Easy to install?
Can you recommend a brand or website to check them out..?
thanks for the input QDUDE79
neal
