saggin in the rear
Old Jun 12, 2008 | 01:20 PM
qdude79's Avatar
Got them off of eBay, Daystar is the brand. 1.5" spacers. Also ordered Gabriel Highjackers from Autozone website. A bit difficult to weasel in, as rear end sag is limited by the brake lines when on jackstands at full droop. Other than that, accessing the top of the shocks was a bit tricky. Going to add 1.5" of shimming to the underside of the top of the shock to compensate. Rides great! Haven't towed or used the airshocks yet, though. It's under construction and only get taken around the block to "test" things as I add them. Not even registered, currently. Figure too that I replaced the entire front steering and shocks at the same time, so if you don't your results may not be as dramatic. Mine was sitting on 18+ year old components, all original. Shocks so bad that a bug hit the windshield and I got seasick!
Old Jun 12, 2008 | 01:59 PM
Crawdad's Avatar
Originally Posted by qdude79
I put some spacers in there (1.5") so I could retain my stock ride. Ordered air shocks to fit for heavier loads and when pulling my bike trailer. Haven't tried 'em yet, as the front end is under the knife. It was cheap and easy, once you wrestle the spacers in.
Yep. Go to SDORI.com and order some $79 coil spring spacers.
edit: You can get Daystars, but they're more expensive, and SDORI is a board member (elripster). Support his business if you can.
Old Jun 13, 2008 | 12:28 PM
yota4life6's Avatar
THANKS GUYS!!! will def. check them out...
Old Jun 13, 2008 | 12:36 PM
Jackal's Avatar
you should have scrolled down the thread list before asking your question. look at my thread on the replacment coil springs i got for my second gen:
my thread
do not, i repeat, do not get coil spacers unless you are getting new springs as well!! the old springs are crap and bouncy. its better to just buy taller springs or the moog replacments.
i dont know about the air bags, but from what ive heard they are mainly for the purpose of heavy loads.
Old Jun 13, 2008 | 12:49 PM
  #25
crawyota's Avatar
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
I also have a 95 4runner. it had the sagging butt. i just replaced the factory coilsprings, with springs from landcruiser fj 80 , and now there is no sag.
Old Jun 13, 2008 | 02:43 PM
  #26
qdude79's Avatar
How do spacers change your spring rate, be they new or worn out? If they're "bouncy" check your shocks. Stiff or saggy, new or old, springs are going to do just that without good shocks.
To each his own. I'm happy with my setup. Maybe if I drove with new springs I'd have a different opinion. Don't know...
Old Jun 17, 2008 | 08:05 AM
  #27
Jackal's Avatar
judging from your pic, you seem to have some MAJOR sag in the rear.
spacers are only useful if you need them because of a bj spacer or cranked torsion bars. the only way to do true justice on the rear is to buy replacement or hard-core coil springs and new shocks. when i replaced my old shocks, i found out that they were compressed all the way and when i took them out they didn't even extend what a piece of crap those stock shocks were. i got the pro comp ES9000's but i think next time i would go with bilsteins.
Old Jun 17, 2008 | 02:59 PM
  #28
Crawdad's Avatar
Gonna disagree with that. If your rear coils are completely shot and have no compression left, then sure, replace them. If they have just settled an inch or two like most have, then adding a rear coil spacer will put you back at factory height. Since those springs are already worn in, they will be more flexible and soft than most lift springs.
Moog springs (and any springs) are also going to eventually settle, too.
Old Jun 17, 2008 | 03:35 PM
  #29
Jackal's Avatar
whatev its a matter of oppinion
okamikai
Apr 30, 2018 10:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
